So i was changing my cam cover gaskets today and i noticed on the intake camshaft these scrape marks that are on the rough part of the shaft (not the lobes)
What do you guys think could cause this? Is this something to worry about?
Also, i noticed on the inside/behind the throttlebody this oily black grime covering the inside of the intake manifold, wiping my finger on it, looks like i just wiped some wet black paint or something.
Any ideas/info would be appreciated, Cheers.
Edited by LANDSCRIBBLE
https://www.sau.com.au/forums/topic/374665-camshaft-scraping-marks/
that oily black stuff inside the manifold is in fact oil. it gets there via the PCV as well as from the very small amount of oil that leaks from around the turbo seal.
as for cleaning it out, it is best done with the maifold off, but using a foaming upper engine cleaner while the manifold is still installed will take a small amount off, but expect it to foul the plugs up in the process (as it washes it down into the cylinders to be burnt up and/or pushed out the exhaust). turns the car into a bit of a smoke machine. it's somewhat amusing.
as for what moodles said about causing idle problems, if you were to then give the throttle body a good proper clean afterwards you shouldn't have any issues. you may have to initially adjust the idle though.
you don't really need to clean it out though. it doesn't have much of a negative effect unless there is copious amounts of oil there, in which case it will make the car a little bit more prone to pinging from what i understand.
Ok cheers for the input guys. Could i not take the manifold completely/TB off and soak the sh*t out of it? I just dont like the sound of pouring stuff into the engine that isnt petrol or air lol.
One more thing aswell! These 2 hoses marked in the pic, are they under alot of pressure? one side on each of the hoses split when i put them back on. Ive done a MacGruber and wrapped some plastic bag around it and cable tied them for the time being, was just wondering if i will arrive at the nissan dealer with oil spurting out everywhere. Thanks again.
http://www.youtube.com/watch?v=1U-0SHUD7aA
under no pressure at all really. they are just breather hoses. you could replace it with garden hose in the short term.
as for putting something other than fuel or air into the engine, i'm sure plenty of people initially thought the same thing about diesel, ethanol, methanol, LPG and various other things that are used as fuels and/or additives. the foaming engine cleaner is designed to be run through the engine.
but yeah, taking the manifold off and giving it a thorough clean is the best option if you want it fully cleaned. this would also allow you to use an aluminium cleaner to really get it clean.
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
