hey guys, i need a hand with the settings on my boost controller and possibly where i've placed my vacuum lines and such.
i have a turbo back 3/3.5" exhaust with a high flow cat, front mount intercooler and a pod incase you need to know.
sounds pretty dumb but i don't know how to set the boost,
i thought one setting was 7 psi and the other at 10 but my boost gauge went up near 15 psi and i'm aware you shouldn't go over 13 psi on a stock turbo
the boost controllers pressure signal is tee'd in at the fuel pressure regulator and the gauge at the back of the plenum at the stock boost controller/gauge i'm not sure how accurate that is.
have the boost controller solenoid hooked up to the wastegate properly, i presumed the line coming from the intake pipe infront of the turbo was good enough for my pressure line then it said the 3rd port you vant to atmosphere but i have it venting into the intake pipe going to my intercooler
i have searched and read through the manual and searched some more
sounds like you have the solenoid lines wrong. run a line from the nipple on the cooler piping (after turbo) to the com port of the solenoid. then run a line from NO to the wastegate actuator and leave the 3rd port open to atmosphere (you could plumb it in before the turbo but its not needed, just make sure its not blocked and doesnt see boost).
ohh ok, yeah that makes sense. Thanks mate =)
i'm also thinking of moving the boost gauges Tee peice into the vacum line for the blow off valve
No you dont want to do that. T it in to the line that provides your fuel pressure reg with a vacuum signal.
If your lines are setup as per the diagram it should work fine.
Start off setting up the eboost with a reset. Then go for a drive and make sure its not overboosting. With everything reset to defaults it should run the lowest possible boost. Then, and only then should you start playing with the settings.
wait, is your engine a 3.15L?
so a bored out rb26/30?
    • Yeah that's true, but idk. Only a 6 month lifespan seems a little short. Oh also, is there a preferred way to send images? Like any sites? I'm used to just being able to upload them lol
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
