either the button isnt tight on the stick, pull the bottom of the stick down and make sure the sirclip is in the correct spot.
or u have to have the key in the ignition and foot on the brake otherwise it wont move
yeah you need the ignition on and your foot on the brake pedal.
if thats not working, its probably the solenoid that activated the locking mechanism. there is a manual override next to the park position. pull out the little stopper and stick a screwdriver in the opening. it will release it
this is on an M35. C34 might be similar.
Hey thanks for the help guys. My foot is on the brake. I know I have to do that for the shift lock. On the c34 I can't see any manual release thing for a screw driver. I do know what they look like I've seen them on new cars. I am looking for it. Where is it? I have called mechanic b says it's electrical problem. Because I can hear the click sound when it unlocks but then it won't move dam it.
I DOUBT its an electrical fault.
The lockout for park on these cars runs off a PHYSICAL locking cable that runs from the shifter to the underside of the ignition barrel.
The cable up and to the left of the shifter in this car is the Lockout cable.... see how its been removed for manual conversion. Pull your centre console out and have a look to see if its still in place and then look under your barell to make sure its not causing issues for you.
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=298844
Alrightey I fixed it. It was the ignition cable. Runs from the console to the ignition. I took off all the plastic under the steering wheel to trace the cable to the stick. Injust gave it a pull and it's fixed. I've played around with it and now it's better than before. Thank kidafa for that link and everyone else.
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
