Hey,
I have an R32 GTR, recently replaced the battery due to starting problems. This fixed the issue for a while but am having dramas again:
1. I started my car after work to drive home, it started fine but none of the electrics (tail lights, interior lights etc) worked for the entire drive home.
2. A couple of weeks ago i charged the battery and it started fine.
3. This weekend It started with the help of a jump start, however I tried it again today and it started but as soon as the leads were disconnected the car died.
4. I put the battery charger on the battery whilst in the car but it wouldnt charge at all, the light came on to say the charger is on but the charge light wouldn't light up.
5. I put the battery charger on the battery whilst out of the car and the charger said the battery is fully charged.
6. I've checked all the fuses and they are all good.
I'm thinking the alternator is probably stuffed and maybe even the new battery aswell. Any help would be greatly appreciated and if anyone has any auto sparkies they could recommend SOR.
Cheers.
https://www.sau.com.au/forums/topic/374716-gtr-wont-start/
alternator is fked
only one charger you have tried????
https://www.sau.com.au/forums/topic/374716-gtr-wont-start/#findComment-5977030
I've had a battery charger tell me my battery is full a number of times but after a few hours it starts reading right (Flat) Same battery worked fine after charging it on and off for about 4 days (Slow charger)
And as far as I remember disconnecting the battery to see if the car runs on the alternator only works on old cars where the alternator is in a circuit with the ignition system or whatever.
I would never hook up a charger to any car with an ECU :-|
https://www.sau.com.au/forums/topic/374716-gtr-wont-start/#findComment-5977121
Hey,
Cheers.
Point 1 usually indicates the accessory fuse under the dash, but you've said in point 6 they are all ok. Was it the fuses in the engine bay you checked or all of them?
https://www.sau.com.au/forums/topic/374716-gtr-wont-start/#findComment-5977192
Yeh mate I've only tried one charger, the charger has worked fine in the past, and worked ok on the missus' car. I've checked both engine bay and under dash fuses. All are good!
I'm thinking its the alternator, will take to an auto sparky on thursday. Anyone got any recommendations of an auto sparky or someone that will replace the alternator?
Cheers
https://www.sau.com.au/forums/topic/374716-gtr-wont-start/#findComment-5977289
Sounds like the alternator to me. The battery is probably dead, but the charger is reading false. I've had that happen before. Take the battery out of the car and put the charger on it over night. See what happens then. To test if the battery is dead, turn on all the lights and hold the horn down. If the horn fades to quietness, the battery is dead, if the horn keeps going, there is obviously charged. If the battery has no charge, blame the alternator :)
https://www.sau.com.au/forums/topic/374716-gtr-wont-start/#findComment-5977471
with all the lights and the horn going that will just drain the battery, a good battery shop should test the battery for you, if i were at my shop i would, although it is in kalgoorlie.
they'll have a battery tester that can test the cca (the guts) of the battery although your battery would need to have a full charge,
it's best to charge it on an automatic charger and leave the battery to float before you test it otherwise you'll get a false reading.
also depending on the size of the battery, the size of the charger and how discharged the battery is it will take more than a night.
i reckon it's the alternator
https://www.sau.com.au/forums/topic/374716-gtr-wont-start/#findComment-5977932
if the car dies after the jumper pack is disconnected its gonna be a bit hard to drive it somewhere lol.
option 1: ring anytime-towing for $100 and get it towed to a workshop.
option 2: check the charge rate while its running off the jumper pack, this should point u towards either alternator or battery
option 3: buy a new battery. Dont buy the cheapest battery from supershit either, just a normal heavy duty with caps that you can top up with water. Dont get a maintenance free battery as if you do have charging issues it wont do the battery any favours being constantly flat and recharged. If its not the battery at least you'll have a new one which'll make diagnosing easier.
btw your charger sounds fked, for anyone wanting to buy a battery charger i recommend a CTEK charger i got the 8amp one and it does everything and will fully charge a massive battery in under a day, can also leave it on charge for months without doing any harm.
https://www.sau.com.au/forums/topic/374716-gtr-wont-start/#findComment-5979883
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
