Hey,
I have an R32 GTR, recently replaced the battery due to starting problems. This fixed the issue for a while but am having dramas again:
1. I started my car after work to drive home, it started fine but none of the electrics (tail lights, interior lights etc) worked for the entire drive home.
2. A couple of weeks ago i charged the battery and it started fine.
3. This weekend It started with the help of a jump start, however I tried it again today and it started but as soon as the leads were disconnected the car died.
4. I put the battery charger on the battery whilst in the car but it wouldnt charge at all, the light came on to say the charger is on but the charge light wouldn't light up.
5. I put the battery charger on the battery whilst out of the car and the charger said the battery is fully charged.
6. I've checked all the fuses and they are all good.
I'm thinking the alternator is probably stuffed and maybe even the new battery aswell. Any help would be greatly appreciated and if anyone has any auto sparkies they could recommend SOR.
Cheers.
https://www.sau.com.au/forums/topic/374716-gtr-wont-start/
alternator is fked
only one charger you have tried????
https://www.sau.com.au/forums/topic/374716-gtr-wont-start/#findComment-5977030
I've had a battery charger tell me my battery is full a number of times but after a few hours it starts reading right (Flat) Same battery worked fine after charging it on and off for about 4 days (Slow charger)
And as far as I remember disconnecting the battery to see if the car runs on the alternator only works on old cars where the alternator is in a circuit with the ignition system or whatever.
I would never hook up a charger to any car with an ECU :-|
https://www.sau.com.au/forums/topic/374716-gtr-wont-start/#findComment-5977121
Hey,
Cheers.
Point 1 usually indicates the accessory fuse under the dash, but you've said in point 6 they are all ok. Was it the fuses in the engine bay you checked or all of them?
https://www.sau.com.au/forums/topic/374716-gtr-wont-start/#findComment-5977192
Yeh mate I've only tried one charger, the charger has worked fine in the past, and worked ok on the missus' car. I've checked both engine bay and under dash fuses. All are good!
I'm thinking its the alternator, will take to an auto sparky on thursday. Anyone got any recommendations of an auto sparky or someone that will replace the alternator?
Cheers
https://www.sau.com.au/forums/topic/374716-gtr-wont-start/#findComment-5977289
Sounds like the alternator to me. The battery is probably dead, but the charger is reading false. I've had that happen before. Take the battery out of the car and put the charger on it over night. See what happens then. To test if the battery is dead, turn on all the lights and hold the horn down. If the horn fades to quietness, the battery is dead, if the horn keeps going, there is obviously charged. If the battery has no charge, blame the alternator :)
https://www.sau.com.au/forums/topic/374716-gtr-wont-start/#findComment-5977471
with all the lights and the horn going that will just drain the battery, a good battery shop should test the battery for you, if i were at my shop i would, although it is in kalgoorlie.
they'll have a battery tester that can test the cca (the guts) of the battery although your battery would need to have a full charge,
it's best to charge it on an automatic charger and leave the battery to float before you test it otherwise you'll get a false reading.
also depending on the size of the battery, the size of the charger and how discharged the battery is it will take more than a night.
i reckon it's the alternator
https://www.sau.com.au/forums/topic/374716-gtr-wont-start/#findComment-5977932
if the car dies after the jumper pack is disconnected its gonna be a bit hard to drive it somewhere lol.
option 1: ring anytime-towing for $100 and get it towed to a workshop.
option 2: check the charge rate while its running off the jumper pack, this should point u towards either alternator or battery
option 3: buy a new battery. Dont buy the cheapest battery from supershit either, just a normal heavy duty with caps that you can top up with water. Dont get a maintenance free battery as if you do have charging issues it wont do the battery any favours being constantly flat and recharged. If its not the battery at least you'll have a new one which'll make diagnosing easier.
btw your charger sounds fked, for anyone wanting to buy a battery charger i recommend a CTEK charger i got the 8amp one and it does everything and will fully charge a massive battery in under a day, can also leave it on charge for months without doing any harm.
https://www.sau.com.au/forums/topic/374716-gtr-wont-start/#findComment-5979883
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
