  • Replies 130
Ok 90% certain going over to Tas 2005.Waiting for some airplane tickets confirmation.Could you count me in?
Thanks
Great! We've got a good group going now... Australians, British, United Statesians, Japanese (duh!) and a Norwiegian... how many are coming with you Paal?
https://www.sau.com.au/forums/topic/37474-tas-2005/page/5/#findComment-1050394
Make yourself the shitz mate...
You are delegates representing the largest Skyline enthusiast community in Aust...also shows your drive in Japan is also a Skyline.
Or hook up with C-West like you did last year.
sorry what hotel is that again, might be a bit too king pin :P
Worst come to worst it will cost you what 2000yen for the day.
https://www.sau.com.au/forums/topic/37474-tas-2005/page/5/#findComment-1050928
I`m definitely coming booked flight and all ,but I`m trying to get with one or two more.But since we were in Japan in the summer , they are sitting on the fence at the moment.
https://www.sau.com.au/forums/topic/37474-tas-2005/page/5/#findComment-1051017
Excellent, we are arriving on the 10th and leaving on the 19th - where are you staying?
Don`t decided yet:
May go with http://www.metropolitan.jp/eng/ stayed there in the summer or maybe
Asuka View Hotel.
One hour from Crowne Metropolitan to Chiba.
Maybe staying closer to Chiba would be better?
Are you planning to visit some more tuners(other than Tas) or anything?
https://www.sau.com.au/forums/topic/37474-tas-2005/page/5/#findComment-1056481
What are the start and finish dates for TAS05. I need to go up north to pack a container - I also need to go south for auction (Rezz- do you know Glen and Wada from 4 Wheelers? They are based in Ashiya). I am in.
Ken
https://www.sau.com.au/forums/topic/37474-tas-2005/page/5/#findComment-1076617
Not at all poida.
Give us some details suchs as the dates you will be there and where you are staying and we can work something out
Well what i have confirmed at this stage is
A) Leaving Brissy on the 29th, arriving on the 30th of Nov..
B) Working Visa for 6 months..
C) A place to stay (Tsuru, Yamanashi) For a month or possibly more.. Which may just take me into the first/second week of January and a great time to move to tokyo to see TAS and possibly catch up with a few of you boys.
https://www.sau.com.au/forums/topic/37474-tas-2005/page/5/#findComment-1077866
Ken
No Ken, never met them... they're in Ashiya? I'll keep my eye out for foreigners around here from now on :D
https://www.sau.com.au/forums/topic/37474-tas-2005/page/5/#findComment-1077887
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
