Pretty much, the boot was leaking at both the left and right sides, so I took the time, spent the money and resealed the rear lights even going so far as to use the Nissan sealant at surprising expense.
Well, it rained again, and the boot still gets water leaking in it. Its not coming from the lights, but I suspect its leaking in through the seal of the rear quater panel and the lip of the boot at the top: around that area.
So, has anyone else had a similar problem?
What was it?
How did you fix it?
thanks
I have the same type of problem with one of my R33's.
The boot leaks on one side at a time and fills one tail light. It is an intermittent problem that I cannot replicate by hosing the car and the tail lights have been out and resealed. Depending on which way the car is parked the water gets into the lower tail light,
The car has a factory GTR bootlid and spoiler and I am starting to think that it is leaking through the spoiler mounting bolt holes.
Any ideas or suggestions on what to try next would be appreciated. :thanks:
My R33 leaked on the left side from the top, inside the gutter the boot closes over.
It soaked one of my amps hence I could determine the position of the leak.
It appeared to come through the bolt which fastens the hinge for the boot.
The bolts just go through the base of the gutter with no rubber washers or sealant.
My car was in a prang years ago, maybe the panel beater missed it.
Lucky for me my car is black, so I used black Sikaflex and just neatly smeared over the hinge mounts and bolt heads.
Also when this leak happened, my car was facing down hill, which makes the gutter fill up.
So far so good.
  • 2 months later...
update, its wasnt the weathering strip, or not that i could tell. I tested the boot by pouring water over various parts of it repeatedly, and foud water entering from 4 + parts, including some seams of metal panles. I puit leftover sealent stuff there, but annoyingly there are still decent leaks which somehow let water get in on the L and R sides of the boot. Dispite all my testing, i have noidea how the funk this gets in the boot, its crazy.
Currently im fed up and have given up, and with the weather getting cold over here, i dont know when i will get to attempt to check more stuff. Im wondering weather the boot rubber seal is somehow letting it it, but thats just a last ditch guess.
this sucks
get some baby powder (or similar) and sprinkle it up and around the in side of the boot,when it next rains you will soon be able to determine where the water is coming in, had the same problem with my 300C, it had been rear ended at some stage in its life and the boot hinges were slightly buckled to the point where the boot lid wasnt sitting on its seal allowing water to enter
Short of locking your G/F in there and taking the car through the automated car wash, the above advice is good!
tempting to lock the GF in the boot right now anyway. . .crazy b@#ch
Mines leaking in the same manner and I traced it to the boot gutter where it looks like the seals are cracking. Am pretty sure it is not the boot bolts, and hinges as the leaks come from before that, and it is not the rear glass either. I like the baby powder idea so I will give it a wack. Weather has been nasty so I can't get it done, will use clear enamel paint in several layers until I can get it properly fixed.
My 4 door was leaking, resealed the tailights, still leaking. Replaced the bootlid with spoiler with a spoilerless one, problem solved. Looked like it was coming in through the spoiler holes. The rubber gaskets were pretty dried out.
    • With stone chips, you really can't just try to fill them. You really have to sand that spot to lower the edges of the chip, so that the filler will end up covering a wider patch than just the chip. Otherwise, you're trying to have a sharp edged paint surface match up to some filler, and they just do not sand the same and you always end up with a noticable transition. A bunch of adjacent chips should be well sanded back, to round off all those edges, and use a lot (in a relative sense) of filler to raise the whole area back.
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
