Parts in used condition and stated for each item.
Pick up only for larger items.
post-12712-0-80962700-1313921277_thumb.jpgpost-12712-0-42198300-1313921452_thumb.jpgpost-12712-0-61745500-1313921415_thumb.jpg
R32 N1 headlights. Has brackets for the grill. These are in great condition, was going to go on my 32 but I sold it.
$200 SOLD
R33-34GTR aluminum washer bottle, straight bolt in, fit your pumps off the plastic one.
$50
Boost controller bleed valve
$10
Was on a 32GTR, blitz style, works fine
$20 SOLD
GTR front left driveshafts, condition as per pics. One needs a regrease and a new boot, or use shafts as spares.
$50 for both
GTR fuel rail and adjustable fuel reg with braided lines. Rail is cracked at the end from thread, requires welding, but no leaks there.
$30 SOLD
honda DC2R radiator, condition as is, no holes.
$50
Rays nismo LMGT1 center caps, 3 only, lost one. Good nick
$100 SOLD
Plastic aftermarket RB26 from belt cover, was purchased from UAS, spray it any colour you want.
$20
post-12712-0-69886400-1313921460_thumb.jpgpost-12712-0-91780600-1313921444_thumb.jpgpost-12712-0-69886400-1313921460_thumb.jpg
LH N1 R32GTR headlight, has chip, otherwise fine, remove the glass and gut it out for a custom cold air intake!!!!
$20
R32GTR N1 rear boot lip, back has raised bumps in it from age, common problem.
$20
R32-33GTR gear sticks, standard. Cut em down for a short shifter...
$20
R32GTR Standard front upper arms in good condition.
$20
R33GTS-25T Wolf computer, came off a series 2.
$100 SOLD
R34 3inch stainless steel cat back exhaust, was off my 34GTR, should fit GT-T and NON turbo!
$200
From 99 vspec 34GTR 80,000km
Factory fuel pump and pickup, good condition, selling due to fitment of nismo pump.
$100
R34GTR front and rear swaybars, factory in good condition.
$50 each, $80 for both
Sabelt 3 point harness, used once to test fit to 32GTR. Looks good in car!!
$50
2x Z32 Air flow meters, done 80,000kms or a lot less.... Tops have been opened to check connections, and then resealed. Includes filter adapters.
$100 each. SOLD
Postage at buyers expense.
Pickup of larger items only.
Postage of items: registered post. No responsibility will be taken for loss of items once posted. It's up to the buyer to sort out insurance ect.
Contact: PM or reply.
  • 1 year later...
  • 1 month later...
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
