R32 PARTS - WRECKING WHOLE R32 , SOME RB20 PARTS STIL AVAILABLE, FEEL FREE TO ASK
LOCATED IN MERRYLANDS - NSW
RB25 GEARBOX - 5 SPEED MANUAL. WITH SHIFTER AND LOWER SUPPORT BRACKET, 66,000KMS -$1300
R32 - GTS BONNET, MAROON - $120
R32 DOORS, MAROON (COMPLETE WITH WINDOW & DOOR TRIMS) - $120 EACH OR $200 PAIR
R32 GTS DIFF - $120
R32 GTS FUEL TANK - $100
R32 HEADLIGHTS (GTR, CLEAR?) - $200 (pair)
R32 GTS FRONT STRUT (ADJUSTABLE) - POLISHED ALLOY WITH RED MOUNTS - $100
R32 FRONT BAR (MAROON) - BEEN CUT TO SUIT FMIC, MINOR CHIPS IN PAINT $150
R32 BOOT LID (MAROON) - $100
R32 TAIL LIGHTS - $150 (PAIR)
R32 REAR BAR (MAROON) - $100
R32 GTS WINDSCREEN, NO CRACKS/CHIPS - $100
R32 GTS REAR WINDSCREEN - NO CRACKS/CHIPS - $100
RB20 CYLINDER HEAD (HEAD, CAMS, VALVES) - $300
RB20 CAM COVERS - $80 (PAIR)
RB20 A/C PUMP - $100
R32 FRONT FENDERS (MAROON) GOOD CONDITION - $100 EACH OR PAIR $180
RB20 COILPACKS (AFTERMARKET) - $220 SET (X6)
R32 GTR FRONT MOUNT INTERCOOLER, SOME DENTED FINS AND TUBE, COSMETIC DAMAGE, HOLDS PRESSURE - $75
R32 REAR SEAT - $140
R32 GTS - FRONT LOWER CONTROL ARMS - $100 PAIR
R32 CASTOR RODS -$80 PAIR
R32 DISC BRAKES (CALIPERS, AND ROTORS, FRONT CALIPERS PAINTED RED) - $350
R32 LOWERED SUSPENSION - $300 (SPRINGS AND SHOCKS)
R32 BRAKE MASTER CYLINDER - $80
R32 FUSE BOX - $20
PLEASE NOTE, I AM NOT ON HERE FREQUENTLY - SO ANY QUESTIONS OR TO ARANGE PICK UP PLEASE TEXT ME ON 0434 080 676, AND I WILL GET BACK TO YOU WITH A ANSWER, CHEERS.
GAVIN
https://www.sau.com.au/forums/topic/374763-r32-gts-parting-out-sydney/
Hi I'm after some interior parts, the Ignition/steering column plastics, the kick panels, map light etc.
also after the front wheel arch plastics if still there.
please let me know if you have a fair bit left and i will come round.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
