Thought id jump on the YouTube bandwagon!
This is taken from my 'black box' recorder i bought online. Its not super good quality but its a neat little recorder with built-in GPS and stuff!
Commentary in the video is courtesy of my mate Tom in the passenger seat hahaha
  • Replies 76
Last session of the day for me in my super slow R32 GTR. My passenger and I with our girths combined weigh over 200kgs so this is close to a 2 tonne tank on 245 Federal 595 SS tyres.
First go with the Contour GPS camera and Dashware too.
Awesome day. Thanks to those who made it possible. Because of the wet track I learnt a heap about the handling of my car and it was a whole lot of fun. It was the first time id had it on a circuit (appart from Canberra Texi back track about 3 years ago) and i was very surprised how well it handled such a wet track. Although I dont think my new found power assisted in any way! A very well run day and id certainly do it again with a wet or dry track.
Tim.
Ok, so I know you guys are going to HATE me but I felt I needed to share this. I got to go back out on Monday to MDTC and it was mostly dry day so very little standing water on the track.
Oh let me tell you how fun this track is in the dry!
My Best Wet Lap on Saturday was a 50.8 and my best on Monday in the dry was a 45.5 :w00t:
These weren't the fastest laps but it got so fun sliding the GTR around in the dry that I really stopped caring about the times.
If you get bored be sure you fast forward to last 1/2 of the video - that front angle is fantastic for showing how it "feels" to drive.
love your work Eric, gotta admit i jumped to the 2nd half for the edge of your seat camera angles, in fact this thread has turned into t a great compare of video brands, angles and placement.
I think im going have to hand out some awards here..
Best Quality picture goes to.... Contour HD
Best camera placement and field of view ....GoPro
Best off camera commentary......Black box
(eg. "F**k me dead bro..its F**king INSANE, the font wheel drift is F**king INCREDIBLE!")
gold..
Well don't judge the picture quality by the streaming stuff we put up. The original cut was 1 gig for 7 minute and Vimeo spat the dummy. I had to drastically reduce the quality to get the whole thing up. You should see the high quality version.
Looks great Eric, definitely some quick laps going on there! How's the front right tyre?!?! At times looks like it is coming away from the rim a little bit under extreme cornering.
Not sure if I've posted the image properly but I love it!
Yeah, I was amazed at how much the front and rear tyres pull away from the rim. Not too shabby too for 6 year old Pirelli's! (Hey they were UBER cheap).
I have some wet footage too but it isn't nearly as impressive. I have to say that the track is a totally different experience in the dry. I started the second day working the speed up since my previous experience was in the wet. The Grip level on the track, as you can see, is terrific. You can really push the car to the limits and there are really only a few spots where it might get away from you. The rest of the track is Go HARD GO GO GO!
First session of the day on the dry yeilded a 48.4 and that got down to 45.5 before I started getting too enamoured with sliding around to care about track times. Happy when the lap times drop that much!
I am so looking forward to Wakefield, I may/or may not beat my PB, should be the last outing for my old semis though, some new Khumos should be good though.
That's if I get more than 3 laps.
I didn't take a lot of pictures during the event, but I did manage just a few snaps. Who else got pictures? Anybody get some nice shots of my car?
and last one... How'd they make GD2ILA shuddup!
Oh....I owe a description on 'heel-toeing'!
So you are cruising along at, say, 80klm/h. If you are on the road, you are probably in 4th gear at about 2000rpm. But you could also be in 3rd at about 4000rpm or even 2nd at about 6000rpm if you feel nasty.
Now put yourself on a race track, heading towards a corner where you know you need 2nd gear....but you are in 3rd.
When you are ready to hit the brakes, there is lots to do.....pick the right braking point, brake hard enough to make the corner, pick the right turn in point, look at the apex and corner exits. And of course get back to 2nd gear to exit the corner without bogging down!
So, you hit the brakes, clutch in, back to 2nd gear, clutch out....and you head backwards off the track. (or more likely, you hear a brief chirp and a wiggle from the rear and you get away with it).
The problem is, you have changed from 3rd to 2nd in say 1/2 a second, forcing the engine to accelerate from 4000rpm to 6000rpm in the same time. It can't speed that quickly and the rear tyres lose traction (compression lock) until the engine gets to the right revs.
The good news is, it is easily fixed and avoided, in 2 ways. The best way is to learn to heel-toe, and practice it whenever you can. Simply, heel-toeing is having one part of your right foot (normally the ball/toes) firmly on the brake, and without lifting off the brake, use your heel to blip the throttle while the clutch is out. If you rev the motor from 4000 to 6000, then let the clutch out, you will get a beautiful smooth downshift, and still be braking hard all the way. In fact if you get the revs spot on you won't need the clutch to select the new gear at all.
The other way to avoid compression lock is to change down gears late in your braking. Easier technique but hard to time and still not as smooth as heel-toeing. If you wait until you are travelling at say 50 instead of 80, you are less likely to lock the wheels because the engine has to change less revs when you change gear (eg 3000->2000 instead of 6000->4000), you will just challenge the gearbox synchros more. If you aren't confident with heel toeing, you must change down gears late in your braking to drive safely on the track!
Unfortunately....the track is the easiest place to practice heel-toeing because there is a large change between gears. You can and should practice on the street, but when you only have to blip the throttle 500 revs instead of 2000 it is tricker to get get spot on. Even so.....give it a go every time you can!
Edited by Duncan
backwards!
The problem is, you have changed from 3rd to 2nd in say 1/2 a second, forcing the engine to slow from 6000rpm to 4000rpm in the same time. It can't slow that quickly and the rear tyres lose traction (compression lock) until the engine gets to the right revs.
umm dunc isnt it the other way around.. you are going from lower revs to higher revs and the engine cant speed up fast enough and hence causes compression lockup from the synchros not matching fast enough..
Dave, if you've got to the point of compression locking, that means that you've managed to get past the synchros, got the car in gear, but the revs are still too high for the wheel speed.
Also, further to Duncan's post, learning to correctly heel-and-toe early before you get into a corner will help with engine braking, taking some of the pressure (and therefore heat) off your brakes.
Thanks Duncan,
Maybe that's why my clutch is making a strange humming noise now lol.
Think I stuffed it, in reverse with my foot on the clutch is hums, take my foot of the clutch an put it in neutral and it goes away. Only in reverse too.
Synchos maybe?? Or clutch?
    • How f**ked am i? what would happen if i leave the magnet inside there?
    • I'll update you guys when i get home from work, im going to try to fish it out.  I just realized that i can't even drop the oil pan. The whole front diff and axles are connected to the oil pan... is it even possible to drop the oil pan without taking out the motor?
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
