Oxygen Sensor (O2) In R34 Gt-T
Can you measure resistance between the pin you're wiring to, and the sensor ground?
Not 10 out of 10 crap. But just so......disappointingly....bleh. Just didn't do anything well. Everything was bland. Didn't even have a long enough life to justify the ongoing daily disappointment. Although I was so happy to see them go that I'm glad they didn't last longer.
Not enough to make any difference at all.
Don't they cool down technically when you're sitting at a set of lights?
The circuit if not a resistor divider is using an opamp to deliver a specific current normally. By maintaining the current as resistance changes, the voltage does too. Add to that, thermistors are normally non linear too,which can make creating a function impossible. Most uses of a thermistor people will utilise a lookup table to get the corresponding temperature.
