Ok so i have full 3inch exhaust, turbosmart manual boost controller, fmic, auto meter liquid filled boost guage and splitfire coils. i have my boost T going from actuator to fmic plumbed into the bottom pipe of the 2 intercooler pipes. The other pipe that goes to plumbback pipe is blocked off.
My question is that my boost keeps changing ranging from as low as 5 psi up to 11 psi i would like it to stay around 10 psi dont mind little creep. i have done the tuning thing with my boost guage and set it to 10 psi and then later on it will change and change through out the day. Im not sure what it is because if it is set up properly my boost should hold 10 psi all the time right? doesnt matter about if its cold or hot because the same amount of air is being pressurised and bleed off right?
and im not talking about spiking and then setteling like bleed valves do somtimes, its when i hold my foot down that i take my boost reading.
Any ideas and help would be much appreciated :)
cheers Kurt
https://www.sau.com.au/forums/topic/374867-boost-issue-yes-another/
"i have my boost T going from actuator to fmic plumbed into the bottom pipe of the 2 intercooler pipes" man wtf does that mean ? re read it yourself
are you tryin to say the boost tap is plumbed in a line from the ic pipe to the actuator ?
what car is it ? what turbo ?
have you removed the factory solenoid?
ok its rb25det r33 series 2 stock turbo
sorry my bad got my words mixed up so i have my boost t in between the wastgate actuator and is then plumbed into my intake intercooler pipe from the turbo... the bottom one, i have the factory solonoid just sitting their with no pipes but still has electrics connected.
cheers
I also had this exact problem with a manual turbosmart controller. I never ended up fixing it unfortunately I just went back to the stock solenoid with the permanent high boost mode and due to the fmic it constantly sits on about 9psi with no realll hesitation like I did with the manual controller. Maybe give that a go if u can't ever figure it out?
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
