Hey guys, I've got a r33 series 1 gts-4
And I'm looking to put a turbo motor i'n it, from what I've been told I'll need a stagea motor.
I Just wanted to know if I'll have to change my loom?
And if i buy a motor, loom and computer package from a stag
It would mean the computer would be suited for an auto?
Meaning i would need a manual computer from an r33?
I also was told the sump would be different, I'm Just trying to figure out what i need to do, any help is appreciated!!
https://www.sau.com.au/forums/topic/374904-gts-4-motor-conversion/
RB25(4WD) stagea motor. Its just a turbo gts-4 engine so it will fit no problem
and also RB26 will fit in no problem but with more parts needing to be changed ... obviously
It will work fine with the loom you have now but not very tidy, they are different looms. You will spend more money keeping your old loom because you will need a boost controller or you will be stuck at about 6 psi. But if your looking for over 200kw + in the near future then your going to end up with a boost controller anyway so fit it while you have the easy chance.
You can use a r33 ECU being a manual because stagea manuals are pretty rare or even a 300zx ECU with board modifications and NISTUNE (good power :thumbsup: ) . It all depends on what you want to do.
The sump is not a problem. Its the same on a stagea as a GTS-4
In the end you could use the ECU you have now aswell. Just saying you can use any ECU but because they have different features E.G. a r32 GTS-T one would be fine but you wont be able to have VTC.
Best thing for you to do is look into a AFM tuneable ECU or even better a MAP-able ECU as they are a lot more fun.
what is a map able ecu, like a Power FC? also would you just suggest a r33 GTST loom and a power fc to match?
Yeah it just needs to be a ECU for series 1 or series 2 specific if hes leaving it stock or it will idle wrong and wont rev over 3000rpm. The wiring hardness's are also series 1 or 2 specific but not so important if the differences are turbo and NA (already stated those above).
A power FC is a ecu that can tune itself around sensors like the AFM etc etc, so if you want to change things like BOV,Injectors etc etc you can work around stalling isues and other things like idle and tune the car but because your using sensors to do it you have a limit to power and how well it really works. With a MAP readable ECU it reads manifold pressure basicly its a better way to calculate everything, way more power, way more accurate and dont need to use things like air flow meters.
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
    • Yes shipping here can be a pain, was about to purchase timing belt replacement kit, but it tends to get expensive due to shipping (and customs if importing from non-EU which the UK now falls under).
