Right Im not exactly sure If i have the right wording but whatever it is I need a new one, (wooden tray sitting just above spare wheel). Basically once upon a time my boot leaked and made the old wood and carpet rather saggy, so ive chucked them but I want to put in a new piece of wood. I have since siliconed and fixed the leak and dried out the boot but now I want to fit a new wooden piece. It may seem easy but I was wondering if people had a good way to go about this? I was thinking of gluing and stapling the carpet to it so its just one piece but has anyone got some Ye 'olde tricks to measure out the size that im going to need, or by odd chance does anyone have a to scale template for a 95 R33 GTS4 boot? :P
Cheers for your help!
https://www.sau.com.au/forums/topic/374916-new-boot-tray/
But it would still leave the edges and I was looking at screwing in my sub box to it? Would it be easiest to just measure basic lengths and undercut so I get the general shape without having to keep cutting it down to make it fit
https://www.sau.com.au/forums/topic/374916-new-boot-tray/#findComment-5981845
Your gona have to go thicker ply if you want to screw your sub box into it, assuming you have a heavy box with 2 subs. And i would make it so that it was fixed so the box didn't slide around if you wana screw them together. It's totally up to you how you want to do it tho, make it sit flush in there, make it larger and fix it to the floor.
https://www.sau.com.au/forums/topic/374916-new-boot-tray/#findComment-5982212
A member on here, Birds, made a thread about this just recently. Called something like "R33 boot install".
Will be more info in there but basically if you want something the size of the whole boot area you will need to make it in sections (or it wont fit in) then either join them together when they're in there or seperately secure each of them to the boot floor...
Personally I would buy a boot carpet from wreckers or here & use that as a template, cut out one piece of wood the right size then cut it into smaller sections to fit it in boot. Would secure (bolt) sides & back, then hinge the section section over spare (if you carry one) for easy access...
Edited by wlspn
https://www.sau.com.au/forums/topic/374916-new-boot-tray/#findComment-5982799
Cardboard template first. If you don't have a single bit of cardboard big enough, grab 2 boxes from slabs of beer and staple them into a giant bit. Then Cut it down to the size you need, test fit if it can be removed, etc...
Friend of mine made a basic timber platform that is bolted on top of the spare tyre which the sub them straps to. Couldn't move even if it wanted to.
https://www.sau.com.au/forums/topic/374916-new-boot-tray/#findComment-5983197
Just went for a temporary piece of 12mm MDF at 85cmX63cm. Fits in with ease but stays snug, Ive a feeling later on when budget permits I'll go for the proper template and fix it in with a hinge just for ease of use and a cleaner look
https://www.sau.com.au/forums/topic/374916-new-boot-tray/#findComment-5995039
  • 1 month later...
Just as update quite liking the look, havent carpeted it yet, but am looking into sealing off the boot sides for 2 8" subs and then having a rectangle flap (this time carpeted) to cover spare wheel. Just an Idea at the moment but will post pictures up if I follow through. MDF holds strong for the sub also just make sure your car doesnt leak :P
https://www.sau.com.au/forums/topic/374916-new-boot-tray/#findComment-6066573
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
