No one likes it, not everyone has it. But I do and it makes me cry, Is there anything I can do to fight the signs of rust and stop them from getting worse or prevent more from turning up. Mine seems to be turning up near the wheels on the side skirts and in the boot? Is there a spray over it option or a use some molding over then spray? really no idea myself.
Cheers guys
https://www.sau.com.au/forums/topic/374917-rust-solving/
There is stuff called rust converter. You can buy it at supercheap. Converts the rust to a paintable primer. Then get some touch up paint and you'll be good. Unless it started to go under the paint then there's no hope. :(
^^ plenty rust converters out there . . a good one that ive used before is called RANEX, follow the instructions and you cant go wrong
https://www.sau.com.au/forums/topic/374917-rust-solving/#findComment-5980026
iv noticed my boot sometimes fills up with water a little bit :S now its a tad rusty aswel...
checked out all the sealant etc andits all still stuck on, i cant find where the water is coming in from...
should i go knock back the rust that is already present and cover that with some protectionism,
then wait to see if i can find streaks next time it happens as i will clean my boot when addressing the rust in there?
https://www.sau.com.au/forums/topic/374917-rust-solving/#findComment-5984321
    • Updated with the latest <68mm Xona Rotor turbos.  The two XRA options are on paper some of the compressor performance I've seen
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
