Selling my track car as need cash for renovations
1990 track only gtr big hks single turbo setup
Hks manifold
Hks waste gate
Big hks/garrett turbo
Large fuel rail
1000cc injectors
Power fc dejetro
Hasnt been tuned for injectors yet
Serge tank and external pump
Stripped interior
Trust intercooler and piping
Fibaglass front bar
Fibaglass front gaurds
Fibaglass boot with n1 lip
Brand new comp stage 5 clutch
Needs finishing but will be a fast car
Internals unknown asume stock
Heaps of spares
Contact 0411672105
Located central coast nsw
$12500
SWAP FOR CHEAPER TRACK CAR AND CASH
https://www.sau.com.au/forums/topic/374941-r32-gtr-hks-single-turbo-setup/
  • 1 month later...
Track only inport...
New yellowjack coil packs and spark plugs starts and runs but rich as. touch up tune and will make 320-350 wkws
Make some offers trade ins welcome
Is this over priced or do I just need to wait for some interest
im not expert but maybe for a non register-able track only gtr.. im looking for a track only gtr but not willing to spend that much. i have seen a few on here (already sold) for around the 7k mark which might be more like it.
http://www.skylinesaustralia.com/forums/topic/358302-r32-gtr-track-car-7000/
That's a good price for a base unit has 1500 in ecu and over 2k on the hot side let alone and also fuel system over 1k clutch band new over 600 that's y I think its worth 10k. It owes more and only had for 6 months and never even drove It
i remember this on ebay from the fiberglass front and the turbo setup, it had 2 sets of wheels on it and said it needed a tune in the post, i remember the price it was listed at but there is no point writing that up, when you picked it up was it running rough?
if so what was the problem?
what things have you done to it since purchase?
and what sort of compression does the motor have?
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
