hey everyone, looking for some help for a mate of mine
car is a series 2 s14 we have just put an rb25 into..problem is the limiter sounds strange, i mean real strange... almost completely flat like a diesel limiter and when held on limiter the car bogs down rly hard and starts to drops rpm....kk dont give me advice on how its a normal limiter and im retarded coz its not!...lol
things that have been to try and solve problem : ECU changed, sparks plugs changed, ign timing checked with light...
engine has had timing belt changed before he bought it, does this sound as though its a tooth out? even though car runs fine and pulls hard for standard turbo....
it is pretty standard with just a turbo back exhaust and front mount and boost t....and splitfires
any help is appreciated.
https://www.sau.com.au/forums/topic/374981-question-about-unusual-limiter/
no we havent... running a standard reg atm with i think a wallbro 255.. will have to check that then... fuel pump is probs ok made 320hp with the sr20 in it before.. cheers for the suggestion
Keep bashing that limiter and you will need to start your expensive conversion all over. The oil pumps in RBs are very weak and make the motor almost suicidal from stock. The reason why is because of the way it is driven off the crank, hitting the limiter will smash the pump to bits and have you nuke your whole motor in seconds not knowing you have no oil flow.
If you did this conversion for a limiter loving drift or burnout pig you really picked the wrong motor. Lucky you this website is filled with an abundance of references to just how bad a choice it was. Just search 'oil pump fail'.
As for the question, sounds like every other stock ecu RB ive smashed limiters with, in fact id be pretty confident I could find a video of my ex diesel limiter RB25.
both of u calm down lol... ino of the problems with rb's and oil... car is used for drift so obviously sees a fair bit of limiter... just after advice on how to fix this...
his old r33 gtst limiter was NOT LIKE THIS... it is not normal...
any more advice?
just thought id post this up because i was warned and its slightly amusing... clipped the limiter driving home tonight and BROKE THE OIL PUMP... haha :)...
to all the non believers u have been warned lol
really? they heaps weak hey?
i wonder why theres so many rb20/25's in drift that smash the limited all day every day without issues ;)
are they different simon? my mates old rb25 copped abused for 2 years before he sold it... like a set of tyres a week abuse... never missed a beat...
different from what? it seems to be the 26's that die before anything else.
rb's not as weak as people make them out to be.
certain parts are (like the pump, as OP just updated with lol)
Otherwise from what I've gathered, some people CAN'T break them while others do without trying....piece of string etc
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 馃槩
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
