Hay guys, my gtt r34 skyline has just reached 100,000 km an in need of a service.
Can anybody recommend a good mechanic in the western suburbs area that does a good job, my mechanic has quoted me $650 inc parts and labour to replace fan belt, timing belt an replace the spark plugs i have used this mechanic on my old non turbo gt r34 when i was on my p's. He did a great job (car didnt break down for the rest of the time i owned it 6 months). So any help would be greatly appreciated.
https://www.sau.com.au/forums/topic/375000-timing-belt-etc/
All good points, although he is a trusted mechanic an at the end of the day as long as he does a good job and it works as it should , at he end of the day it's still a motor regardless of the brand skyline.
Just make sure you assemble all the parts you need to change.
https://www.sau.com.au/forums/topic/375000-timing-belt-etc/#findComment-5981870
its not a days work... its 3 hours if you know what you're doing... ive done at least 100 timing belt changes on skylines now lol.
Lol...I've never changed one and I know this...it would still easily take me a day though..
Plus if your mechanic is nice enough to only charge you trade price for parts, some are but many arent, Id say he is quite easily making a couple hundred off this..still a pretty good deal ..many say you should change your waterpump as well but if your radiator fluid is in good nick IE still bright green and not full of rust scale and your water system is clean I wouldnt worry to much about it..maybe Just throw a bottle of radiator flush in before you drive it to the mechanic and drive slowly, or get him to do it...
https://www.sau.com.au/forums/topic/375000-timing-belt-etc/#findComment-5981901
Jeez your doing well if your changing timing belt and bearings, oil seals, water pump, coolant flush, spark plugs in 3 hours.
https://www.sau.com.au/forums/topic/375000-timing-belt-etc/#findComment-5982035
that sounds pretty cheap...
i just did my second major... i changed:
- timing belt
- water pump
- cam and front crank seals
- timing belt idler bearing
- timing belt tensioner bearing
- air con belt
- power steering belt
- water pump belt
- thermostat
- engine oil
- coolant
- gearbox oil
- spark plugs
including parts and labor i paid $1400... and i still need to get the diff oil changed and a few other bits and pieces...
https://www.sau.com.au/forums/topic/375000-timing-belt-etc/#findComment-5982531
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
