1994 R32 Gtr - Abandoned Project
Hi guys
I have for sale my R32 GTR which I had planned to do a full ground up build on. But pulling the pin on it due to other stuff going on in my life.
I am the only owner since its been in Australia, I imported it a few years back it is complianced and was registered but rego since has ran out. While in Australia I probably only drove it on the actual road for less than 10,000 km. The car was Grade 4 vehicle, with no accident history. When it arrived we only found a a small rust spot on the lower right hand rear panel which we fixed up. All running gear is still in the car, the motor has been pulled out and the interior expect for dash and console assembly has been removed. There is no backseats, roll cage was planned to go in. The underneath and body is all straight.
The body has been sanded back, but still requires further sanding and prep'ing for spray painting.
I want to sell everything as a complete package.
What's included -
Complete R32 GTR rolling shell
RB26DETT motor its done around 130,000 km
- Trust fuel rail
- Sard 700cc Injectors
- Nismo N1 steel wheel turbos
- Exhaust manifolds are slightly ported
- Mines dump pipes
- Cam cover gaskets and all turbo gaskets have been replaced
- NISMO twin plate clutch/NISMO fly wheel
ECU - NISTUNE chipped, safely tuned to 232 rwkw.
ARC front mount intercooler painted black
APEXI twin pod filters
Twin exhaust system
7 point roll cage
TEIN coilover shocks with EDFC damper controller
CUSCO front strut brace
CUSCO adjustable castor arms
Nardi Steering wheel
NISMO 320 kmph instrument cluster (31727 km)
NISMO center console gauges
APEXI boost gauge
RECARO fixed bucket seat (Passenger seat standard)
Top Secret aero kit
Aftermarket fibreglass bonnet
Standard R33 skyline wheels
Asking price $11,500
Great start for someone looking to build a track car or a really unique street car.
Contact 0403596801
post-14134-0-95544700-1314098579_thumb.jpgpost-14134-0-30025000-1314098594_thumb.jpgpost-14134-0-90721400-1314098609_thumb.jpgpost-14134-0-68895600-1314098626_thumb.jpgpost-14134-0-80959700-1314098640_thumb.jpgpost-14134-0-40684100-1314098654_thumb.jpgpost-14134-0-14826200-1314098667_thumb.jpgpost-14134-0-52253500-1314098684_thumb.jpgpost-14134-0-32658900-1314098971_thumb.jpgpost-14134-0-99852200-1314098981_thumb.jpgpost-14134-0-73591100-1314099013_thumb.jpg
Edited by Shakiel
  • Replies 45
PARTING EVERYTHING OUT
HERE IS A LIST OF WHAT IS UP FOR GRABS, PM FOR ANYTHING YOU ARE INTERESTED IN
Roll Cage
Turbo back twin exhaust
RB26 Motor (Mines dump pipes, NISMO n1's, TRUST fuel rail, Sard 700cc injectors, NISMO clutch and flywheel)
TOMEI fuel pump
Standard GTR fuel pump
NISTUNE ECU and GTR LOOM
ARC Intercooler
APEXI twin pod filter with AFM's
Gearbox/transfer case
NARDI steering wheel
NISMO instrument cluster plus NISMO center console gauges
APEXI boost gauge
Aero kit - Front bar, side skirts, rear bar
Aftermarket bonnet
R33 Skyline wheels
Front and rear brake calipers
GTR passenger seat
Headlights
Rear tail lights
NISMO rear lower control arms, rear camber arms, upper arms
HKS piping kit minus HKS pod filters
1994 R32 GTR Shell no accidents. Perfect to drop everything straight into.
Anyone after pics of an item, let me know I'll get it arranged and sent to you.
Quicker responses if you contact me on 0403596801.
Thanks.
Roll Cage - $1,000
Turbo back twin exhaust - $800
RB26 Motor (Mines dump pipes, NISMO n1's, TRUST fuel rail, Sard 700cc injectors, NISMO clutch and flywheel) *DUMP PIPES, INJECTORS, FUEL RAIL UNDER NEGOTIATION* $2,500 with out mentioned parts in negotiation
TOMEI fuel pump - SOLD pending payment
Standard GTR fuel pump - $100
NISTUNE ECU and GTR LOOM - $800
ARC Intercooler - $800 *UNDER NEGOTIATION*
APEXI twin pod filter with AFM's - $300/$150 without AFMS
Gearbox/transfer case - $1000
NARDI steering wheel - $200
NISMO instrument cluster plus NISMO center console gauges - $350
APEXI boost gauge - $100
Aero kit - Front bar, side skirts, rear bar - *FRONT BAR IN NEGOTIATION* side skirts, rear bar $250
Aftermarket bonnet - *NEGOTIATION*
Front and rear brake calipers - $400
RECARO fixed bucket seat - $750
GTR passenger seat - $250
Headlights - $250
Rear tail lights - $150
NISMO rear lower control arms, rear camber arms, upper arms - $250
1994 R32 GTR Shell no accidents, complied etc. Perfect to drop everything straight into - $4500
 Share
    • I did a pretty ruthless clean up before I left townsville. If it wasn't a part to suit a car I currently have it was sold or binned. I have all my stuff organised in big tubs with lids that stack from supercheap and bunnings depending on who was cheaper at the time. Parts were sorted by either chasis/motor/Fabrication/general/electrical. I have a mezzanine that's 7mx2.3m and all lives up there. Easy to access when needed and out of the way.  I also have the issue of selling and dealing with scumplace/marketbook was actually going to list stuff today but couldn't be bothered as been stuffed around too much. I generally let a few people know I want to off load stuff and people pass it on to others to contact me, generally easy sale and I'm never looking to make big dollars. Rather it gets used than go in the bin. Next clean up will be around Xmas and if doesn't go on the s15 it's going bar 2 sets of wheels.
    • Did a little bit on the V37 today. I bought this LED kit out of the US https://www.ebay.com.au/itm/125953603618. Best I could find online but didn't look great, in the end the quality was pretty much right and it did come with locations for each light including rear number plate and a few spares. The factory owners' manual was also useful with information on where to pop each light out without damage. I prefer the LED look as I use it daily including at night and the LEDs are both brighter and the white light is easier to read with. Vanity mirror comparison, LEDs just look more modern The glove box was the only difficult one (and the only one that was previously blown.....), steps were Open glovebox 50% but not fully open Push up on bottom of the box to unclip it on both side, not screws or pins to remove Remove the top stays at an angle, right side then left, because.... Before dropping the glovebox totally, remove soft close clip on left Then, remove 7 screws to release the glovebox surround Twist the globe holder anti clock to release it from the surround In this case, the LED globe supplied was wider than factory and did not fit, so I ground down each side about 1mm then inserted it Last trick, start engine to check the LED polarity is correct, the globe only operates when the engine is running (whether the box is open or closed) I also moved the 4G booster and wifi across from the Fuga, a little frustrating as I could not find a good Accessories ACC source anywhere in the boot so I'll run a wire from the cabin next time I get a chance. Also, unlike the Fuga the external antenna wire does not quite fit between the rear windscreen and the body so I think I'll have to drill a hole in the roof to mount it. Probably not that interesting for most people so I'll just post once complete
    • Pretty sure I could do but it would need to be exported and reimported as the current import approval is race only. But in practice there are plenty of other practical reasons it can't be a road car despite their potential value these days like stripped interior looms, cage to cut out etc Nah, no mods to it other than updating the roll age to current regs. It makes about 350 (laggy) kilowatts on the N1s at 18psi which is enough to push it around the place
    • This is it, folks! Our final event of the year... The big one, you all know and love - Putty Road! It goes without saying, but this is the biggest cruise in our calendar each year! A nice long drive, with a hearty pub feed at the end! Do you need much more enticing than that!?!? So make sure you wash the car, get your cameras out, block out the calendar, and get ready! We know you're all as excited as we are, so make sure you lock in the details and date below: Date: Sunday 8th December 2024 Meet Location: Corner Windsor Road and Groves Avenue McDonald's / KFC (3 Groves Avenue, Mulgrave) Meet Time: Meet at 9:00am for a 9:30am departure Destination: The Royal Hotel, Singleton (84 George St, Singleton) Map: https://tinyurl.com/saunsw-puttyrd Itinerary: We will meet at McDonald's / KFC on Windsor road and from there will head onto Putty Road. There will be a break at the Grey Gum Cafe (8679 Putty Rd, Putty) which we should reach at approximately 11:30am. For all the Newcastle folks this will be a good point to join up. From here we will continue on to Singleton for lunch. Please remember to fill up prior to heading onto Putty Road. There will not be a fuel stop until Singleton. To those running on E85, Freedom Fuel (old United) at Vineyard on Windsor Road has started selling there. At Singleton there is a range of servo's available including BP, Shell and Caltex. There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Back by popular demand - we're lining up another Old Pac Run! Get your cars ready for one of the best night runs on the calendar! So without any ado whatsoever, here are the details for you to save: Date: Saturday 23rd November 2024 Meet Location: Cowan Truck Stop (Pacific Motorway - Refer to Map) Meet Time: Meet at 7:30pm for a 8:00pm departure Destination: Gosford McDonald's (65 Pacific Highway, Gosford West) Map: https://tinyurl.com/saunsw-oldpac Definitely an easy one for this cruise, meet at Cowan Truck Stop and jump straight onto Old Pacific Highway! Final stop at McDonald's which has plenty of parking all around. Please be mindful of the added police presence lately so best behaviour is expected! There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAU:NSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
