specs
CPU maker:amd.gif
CPU:Phenom II X4 955BE
Motherboard:Crosshair IV Formula
Bios:1902
GPU maker:ati.gif
Graphics Card:crossfired MSI HD6870 1GB Twin Frozr II
Memory:G.Skill Ripjaws F3-16000CL9D-4GBRHD (2x2GB) DDR3
Hard Drive:Caviar Black 1TB + Caviar Green 2TB
Optical Drive:ASUS DRW-24B3LT 24X DVDRW LightScribe
Power Supply:Corsair AX1200
Display:LG, 1920x1080
Case:Lian Li Armoursuit PC-P50R
Speakers:Logitech X530
Mouse:R.A.T.3
Keyboard:Saitek Eclipse II
Operating System:Windows 7 64bit
Cooling
CPU:Noctua NH-D14
Graphics Card (GPU):Twin Frozr II
Case:plenty of case fans standard pixel.gif
Speeds
CPU
Stock:3.2GHz
OC'd to 4.0GHz
Graphics Card - Core
Stock:920 Graphics Card - Memory
Stock:1050
Benchmarks
3DMark06:21805
let me know what you think, excuse the phone quality photos :(
Sam
Edited by savage1987
https://www.sau.com.au/forums/topic/375035-first-pc-build-thoughts/
All that and a small monitor? :O
I know...maybe hes saving up for one..lol
all that and one 7200rpm OS drive?!
yeah agreed, would've a smaller faster OS drive..
But you all missed the main thing wrong with it
ITS PINK!!
must be a shirtlifter.. :P
lol!
It's not pink in real life.. just blame that on my shitty phone camera :( it's anodised red.
The monitor is only half of the monitor-ness available, the other half is a 42" LCD TV.
HDD: waiting on SSDs to come down in price and up in size to a point where they become cost effective.
Does the difference between a 7,200rpm and 10,000rpm make a huge difference?
Yeah it's quite a lot faster, but no point buying a 10k Raptor drive these days. SSD's have come down a lot since they came out and destroy them in performance. 10k drives are just too expensive and nowadays are pretty much useless.
There still pretty expensive though hey, like $350 for a fairly decent 120GB one. I guess if you're really into gaming and the like then I guess it's worth it.
I'll just stick with my noisy 7200rpm one :nyaanyaa:
SSD is one of those things you won't 'get it' unless you have used it.
Then once you do you will never want to go back to regular HDDs for the OS boot drive again (unless you got some uber RAID setup with 10k rpm drives).
I just bought my 2nd SSD (120Gb Cruical M4) for my next computer build.
well I got my Raptors at a really good price, which is why I bought them, but TBH, if I were to do it over again I would have saved my pennies up for a Crucial M4 128 gig (have seen too many firmware issues with OCZ ATM). Would not buy one new though.
Velociraptors in RAID 0 are comparable in some ways to a Vertex 2, and when we installed Windows 7 x64 on both setups to compare, took around the same amount of time to install. That said, after using a Vertex 3 in my workstation, I'm sold on the SSD thing even if it's not cost effective; I used to be a big naysayer about the whole SSD + storage drive thing, but they are that much faster it's incredible.
Yeah, that was the reason I went M4 instead of vertex 3.
Now I got 2 SSDs to play around with I'm not sure if I should even bother with setting up that intel smart response storage thingy on my Z68 mobo since I will probably just dump my most played games on my 2nd SSD instead.
Edited by Mayuri Krab
Thanks for the ideas and feedback guys, the RAM I wasn't sure of exactly what spec to get etc and I was really tired of power-researching all the other parts at 3AM so I just threw that on the order to get myself by.
Anyone got any ideas on a set that would work well on this board? I'm running Windows 7 64bit so the more the better, but I don't know enough about timings and latencies and what will fit under my enormous NH-D14! :)
Raptors have been going cheap as fk lately, given people are clearing them out :D
Very affordable next to a SSD IMO. RAID0 them and you are laughing.
I'm still not convined of SSD's very on a $ vs performance scale. Even with GEN3 drives outs now.
I keep reading there are a lot of underlying issues, corruption etc etc. I really CBFd with it until its fixed.
Never quite understood the whole bling-your-case thing with clear side-panels, neons, and glowing fans - basically stuff that serves no purpose besides appearance (not that it even looks good..) I guess it just reminds me of the whole Fast'n'Furious ricer thing. Can anyone explain it? I honestly don't get it :(
All my PCs are flat black, no clear-side panels, basically all that show are a glowing power LED and maybe some USB ports. Simple, functional:
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
    • Absolutely. Look very closely at the photo (of yours) that I took my second snip of. See how the sill is thicker material right behind the pinchweld, where the two notches are? That is the factory reinforced area for lifting. That pad is supposed to carry the weight. The factory jack (go look at it, and how it interfaces with the car at the pinchweld) shows you exactly how the load is carried from the car to the jack to the ground.
