I have just purchased an R32 GTS-T with some mismatched panels, and generally rough paint. This is ok as I want to make it black anway and fit some GTR style kit to it. I've found all the parts and am waiting on delivery, but I am wondering about the painting. What is a good black paint, not a pearl or anything though, I want something good but not super expensive, I am hoping the paint job won't be quite all of my budget and that I will have most of the money left over for a computer. So a good black paint, and maybe a good paint shop that you might recommend that do good work for a good price. I'm not looking to skimp, just trying to not blow my budget, well at least not by too much!
Thanks.
https://www.sau.com.au/forums/topic/375036-r32-body-work/
1- is the car black to begin with, as if this is not the case, you will have a mismatched engine bay, door jams etc etc.
2- black paint has many variants, from a standard basecoat to a metallic or pearl etc etc, different blacks may have a red side tone or whatnot but if you wanted you could go for the standard nissan colour (kh3 from memory) as this has either a standard basecoat or metallic from factory. ask at your local paint supplyer or even a crash shop what the difference is in price and whatnot to find out if they carge more for a mettallic or whatnot.
3- A good repair shop depends on where you are (so location might help) but most panel repair shops should do a decent job of fitting a bodykit and etc, but ask around at different shops to get different quotes and different opinions as everyone does it slightly differently.
Hope this helps in your search to get your car up to speck but to also help us in helping you chose the right places to go and etc.
=D
https://www.sau.com.au/forums/topic/375036-r32-body-work/#findComment-5981666
The car isn't black, it's gun metal, I had a look at the engine bay and I think the difference is not that bad. I am in Western Sydney, so basically anywhere from Parramatta to up the lower mountains would be fine if anyone knows a good place they would recommend. Thanks for the advice, will call some paintshops and just get some quotes on the actual paint itself and see, a metallic would be nice, but gotta check the $$.
Cheers.
EDIT: Oh also need to get all the rubber seals replaced as they are shot, does anyone sell these that are not genuine Nissan? I imagine the Nissan ones cost a fortune.
Edited by cherring
https://www.sau.com.au/forums/topic/375036-r32-body-work/#findComment-5981692
What is your budget roughly?
Also if you find somewhere that does aftermarket rubber seals let me know...
If you have to end up going genuine, which you probably will (I have looked for aftermarket stuff with no luck), that is very likely to blow your budget as from memory all the rubber seals add up to over $2000 alone!
https://www.sau.com.au/forums/topic/375036-r32-body-work/#findComment-5982828
4K wont cover a decent spray job, especially not a colour change... you may find cheaper but it normally isnt a decent job....
4K wont cover spray, computer, rubbers, choose one....
if you get a computer, why, do you have other mods that need it to be supported?
if you get spray save up more first...
if you get rubbers thats atleast $1500 Id be guessing...
your budget is too small for what you want...
https://www.sau.com.au/forums/topic/375036-r32-body-work/#findComment-5983329
Yep am starting to see how pricey it's all getting, but that's ok, will have to choose and then get another budget to go do some stuff after that . As for the rubbers, there has got to be a way to get those cheaper than $1500, sure geniune stuff probably looks all pretty , for a piece of rubber, that's just crazy! So some hunting will have to happen it seems, patience patience :)
https://www.sau.com.au/forums/topic/375036-r32-body-work/#findComment-5983957
What rubbers are worn?
Front & rear windscreens can generally be done with cheaper generic seals but side window seals & trim would have to be genuine unless you're willing to look at good condition secondhand items...
https://www.sau.com.au/forums/topic/375036-r32-body-work/#findComment-5990286
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
