Autoselect Gtr
Year: 1996 Model Year
Vehicle Name: Skyline GT-R
Grade: V-SPEC
Milage: 24000kms
Engine:
The engine was built by AutoSelect Osaka.
HKS STEP2 2.8L Kit
Forged Pistons HKS 87Ф
Forged Connecting Rods HKS H-cross section
Full counter-lightweight forged crankshaft HKS 77.7mm stroke
NISMO water pump
NISMO oil pump
Camshafts JUN STEP Ⅱ IN/EX264
JUN adj Cam Sprockets
JUN valves, valves spring & retainers AUTOSELECT matched & ported head
AUTOSELECT 48mm throttle
AUTO SELECT oil pan
AUTO SELECT anti-Surge
GREDDY Type R Racing Blow Off Valve
GREDDY oil filler cap
AUTO SELECT oil catch tank
Turbine:
Turbine HKS TO4Z 0.81 housing (brand new)
Stainless steel exhaust manifold HKS 45Ф
HKS Racing Westgate
Fuel:
NISMO in-tank fuel pump × 2
SARD 720cc Fuel Injectors x6
NISMO Fuel Pressure Regulator
EARLS fuel hoses
Cooling:
AUTOSELECT 3 layer intercooler
AUTO SELECT one off intercooler piping
HKS 15-stage oil cooler
AUTO SELECT 3-layer aluminum radiator
AUTO SELECT Air Remover Tank x2
SAMCO silicone radiator hose
NISMO Radiator Cap
AUTO SELECT Dry Carbon Cooling Panel
Intake:
HKS pod filter
AUTO SELECT suction pipe
Exhaust:
4" exhaust, HKS external waste gate, HKS ex manifoild.
Electrics:
HKS F-CON V-PRO
HKS EVC
HKS injector monitor
GREDDY oil temp, water temp, oil press, fuel press, exhaust temp & boost gauges
NISMO 320km cluster
NISMO gauges
FIELD ET-S linear torque split controller
Suspension:
AUTO SECECT strut brace
AUTO SELECT adj caster rods
HKS coilovers
NISMO engine mounts
NISMO diff bushes
CUSCO adj upper control arms
JIC adj rear controls ams
CUSCO 4WS disable kit
CUSCO 7 pt bolt in cage
Drive chain:
AUTOSELECT 1.5 LSD
ORC Triple Plate Clutch (brand new)
NISMO clutch slave cylinder
NISMO gear knob
Brake:
BREMBO F-40 brake calipers
ENDLESS 355Ф front brake rotors
AUTO SELECT master cylinder
EARLS stainless brake hoses
ENDLESS Brake Pads
Wheels & Tires:
RAYS 18x10 +15
RE55s 285/30/18
AVS 18x10 +15
RE55s 265/35/18
Exterior:
Serie 2 headlights, AUTO SELECT Yellow Carbon Kevlar bonnet, bonnet lip, guards, front spoiler, door panels, pillar panels, rear spoiler, Carnads, side skirts & rear bar, Bee Racing CF spoiler blades.
Interior:
RECARO SP-G bucket seat
MOMO steering wheel
AUTO SELECT adj boss kit
TAKATA 5-point harness
This car is a super fast car, it pulls 450kw at all four wheels @ 20 psi (safe mode) on 98 pump fuel. Dyno sheet can be showed.
Also, 12 month VIC rego can be supplied for extra cost.
for more deatils please contact me. Any offer or trade-in will be considered, serious buyers only.
Edited by aemotorsport
So it would be mission impossible to get Rego
hi
of course, it cant be complianced or regristed like that.
i have talked to the ppl who do compliance or RWC, the car can pass compliance & RWC. As long as some works done.
RWC & compliance works: replace the CF panels to OEM panels, back to twin turbo set up, OEM air box, OEM driver seat, OEm exhaust, adj to legal ground clearance & some other minor items etc.........
i know the works are not impossibile, just takes time. thats the reason why i need extra money for 12 mth rego, cos i have to leave the works to the workshop to do it. 2nd option for ppl who buy it for tracks.
anyway, pls contact me , if really really want it with rego.
cheers
  • 1 month later...
  • 1 month later...
 Share
    • As far as I know, Infiniti stopped importing vehicles before 2020, even though they were still selling their stock for at least a year or 2 after that, they were older build years, therefore, you can import a 2020 400R, because you couldn't buy an AuDM 2020 built Q50 RS. As for insurance, you might need to go through one of the enthusiast insurance companies, they tend to insure a lot more grey import models than the mainstream insurers as Duncan mentioned.
    • loved seeing the zenvo on the a1 just after the hatfield tunnel i was the guy in the white van trying to egg you on it sounded awesome and those exhausts glowing red inside insane cheers for the thumbs up tim and tom.
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
