Yes, only an issue when there is a device metering the incoming air.
Do you have a breather from your crank case to the catch can? IMO this one is pretty critical if blocking the PCV valve and running at atmo system.
I don't have that breather if the question was for me.
Though yes, I can understand that it will have to BLOW the gasses through my proposed system rather than them being sucked out when the plenum is under vacuum. Not ideal, though will still work.
My ultimate reason for wanting to remove the system is that the fitting on the rocker cover is actually a suspect as well - the whole thing has a bit of play in it. Meh, whatever.
Cheers for the input though guys, at least I know I can give blocking it off a shot anyway without worrying about my crank case becoming a pressure bomb.
There are passages in the sides of the block that are for blowby gasses to equalise with the head. The PCV valve is designed to draw these gasses out when the pressure in there is higher than in the intake manifold (i.e. under vacuum).
I'm at work and trying to focus on things completely not car related so my brain is struggling :P
IN the R32 Engine manual there is schematic of the blowby gas system, might help explain it a little :)
Was mainly for gotRICE but she'll be right :)
It won't ever become a pressure bomb, the worst it could do it pump a heap of oil out the exhaust either via the valve stem seals or the turbo.
I suppose I'll even notice the oil pressure go up on the stock gauge should this occur :P
cheers
Years ago I had a Gemini that had a block filter thingy coming from the rocker cover to the air filter. I floored it at the lights and as the revs got up in second or 3rd (cant remember now, was a long time ago) the dipstick popped out and poured out all over the engine bay and the exhaust. Clouds of smoke everywhere and the guy I was dragging was grinning his head off.
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
