so i clayed my gtr and machine polished with meguires mirror glaze light cut number 2
panels are coming up great, but now i have small spots absoutly everywhere from machine buffing, they are so hard to get off it has taken me longer to attempt to remove the dry spots than to prep the whole car, they seem to dry before i even get to wipe them off. I am in the shade and the car is cool. Do i have to re polish the whole car by hand, windows, trims etc just to get rid of it?
surley i'm doing something wrong??>_<>_<
i want to start on a black car soon as well, but not keen till this is sorted, what do you guys do???
my car is covered in spots and ive been scrubbing for hours :mellow:
variable speed yes, i have used one before, bit i think i should have masked the whole car up, lol
may try a high pressure cleaner today on the spots.
I have not reduced the grade yet. will be next the step.
any easy way to remove dry polish?
You'll probably have to go back over it by hand with a fine cut to get the marks out.
Just my 2c I'm not a fan of meguires cutting compounds, it was drying too fast so left marks every where and just wasnt really that great.
Autoglym make brilliant products for pretty much anything you need, do like the meguires deep crystal wet look polish though.
Got any photos of the marks? It should come off without too many dramas. If you work on an area that is too large then it can dry out and cause a bit of grief. A quick detailer should help lubricate it and get it off.
Also is the buffer you are using a random orbital one or rotary?
yea thats the plan now,
also looked on a detailing site which recommended isopropyl alcohol, just tried it and it works not too bad.
so as your polishing, the polish is drying? even after you've made a few passes on one spot??
or is it splatter/dusting or sorts that is drying onto the panel?
IPA has it's drawbacks, and i hope you diluted it. You're better off getting something like FI Cleanse (light, for smaller cars)
have you been spurring your pads?
sorry, all i meant was the polish was splatttering everywhere, but i have used this product again and use less water and less speed and seem to be having more success, i have a rotary polisher, not orbital.
  • 4 months later...
Sound's like to much polish cut back amount and do smaller sections at a time.
Have a clean dry rag handy to remove this as you go, don't let the over spray dry for to long at all.
Think the cleaning compounds in the polish bite into paint, then dry and there's the problem.
May be try, as polisher starts up slide it along panel a bit to spread polish a bit, so less for it to fling off at start-up.
Cheers.
Keep applying water to the polishing pad as you go mate, And do small sections at a time and keep wiping the excess off With a clean microfibre towel. Most important thing is to keep the pad wet, and If your new too detailing use A micro pad instead of sheep wool (a lot easier to damage your paint)
Hi,
If you have a foam gun accessory for your high pressure washer, I would mix 1/4 car wash, half of that again with an all purpose pH neutral cleaner and rest water. Foam the car and let it dwell. This will soften the polish specs. High pressure rinse, then wash the car with normal car wash.
If they are still there you can lightly clay or wipe the car down with a solvent like Prepsol. This should remove them and be alot quicker than going over the car again with a polisher.
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
