hi mate
if you are running a 4wd adapter with external oil pick up.......
how does your external pick up look like ?
can someone show me some pics on how to correctly set this us ??
do i have to block the holes for the oil feed in the block from the oil pump ??
thanks
hi mate
thanks
I had a few pics laying around I picked up over the years.
I would presume you have to block the feed in the block from the oil pump as it will feed from the pump externally.
Doing mine atm will take a pick of my setup when I have finished anything. Yes u have to block the old pickup off anything else In particular u want to know mate
Edited by t04z
  • 4 weeks later...
sorry it took me so long only just got my sump back this is how i have done the internal side of things went with that side cause it was to much of a headf**k to come out the otherside will run 3/4 stainless piping round to the oil pump
    • I already got plug and play Link ecu G4X. Main concern is that the de loom works on s1 motor or not? I already rewired injector and coils loom to suit my bosch injectors and bosch vag coil. I’m not running any Iacv. For cas running the nz wiring kit i bought the neo plug one so it suits the wiring but don’t know it works or it doesn’t matter they work the same on every motor. For wastegate solenoid do i need to wire straight from ecu? What can i do for iat sensor to work or same run from ecu? For Vct solenoid, right now i got s1 vct solenoid on motor so do i need to remove neo connector and add s1 connector to work? Any other thing i missed i need to do to make the motor working on de loom. Any different mechanism on neo vs s1?
    • Yes I was planning to get it to a tuner with a dyno, but they told me to wait till September because the heat really started now and it is not ideal to do it in this heat.
    • Next week man, no rush on the postage
    • Hello everyone. I believe I have s1 headlights but I just wanted to make sure and getting confirmation from you all. Thanks in advance for your help!
    • Crazy how good the aero bar looks compared to the stock one
