Hi Everyone,
I am selling my K-Speed (Volk Racing GT-C replica) 18inch wheels. They are off a R32 skyline and fitted perfectly without any modifications etc.
They will also fit R33's and R34's plus other vehicles with a 5x114.3 lug pattern.
The wheels are 18x7.5 with 235/40 tyres for the back & 225/40 tyres for the front. 3 tyres have about 95% tread while 1 almost requires replacing.
They are overall in good condition with only the odd chip/graze.
Ph 0417 471 255 or PM.
Cheers
post-23049-0-75916500-1314183500_thumb.jpg post-23049-0-73866500-1314183578_thumb.jpg
https://www.sau.com.au/forums/topic/375132-k-speed-18inch-wheels/
