Its easy to talk shit on the net isn't it. You blokes keep believing that petrol goes in the oil hole. :worship:
you do realise theres a BIG different between petrol and diesel yer? because running petrol would be kinda gay, diesel not so gay
  • Replies 45
Mate you say there is a big difference between diesel and petrol. Yeah there is a SLIGHT difference. You do realize there is a BIG difference between oil and diesel yer? Sarcasm meant but no offense. :thumbsup: How much 'oil' pressure do you reckon you would get running something so thin through your motor? The likelihood of scoring the big end bearings would be very high.The mains might be alright but there is still a very high risk there also. Its not that hard to pull an engine to bits, clean it properly and put it back together. Sure you can take shortcuts and still drive it away. But would you take the risk?
So if anyone here can back up their words then do it. Get out your camera and film the diesel, petrol or kero going in the oil filler hole. Start the vehicle and show us the oil pressure gauge. Film the bottom end knock that will ensue. Grow a pair, put up or shutup.
lol :)
You aren't meant to start it fool.
My understanding is you take plugs out and block the plug holes. then crank the engine over and over with the starter motor or manually.
Turning the car on would be stupid. the "run" meant "put" when saying run diesel through it.
lol.
A while ago I replaced a head on an RB30, and while the head was off I flushed the block with white spirits.
Motor still runs fine today. But of course it may be a different story if its been sitting around for a while full of milk - if you havent had a look at the bores
lol :)
lol.
Wait what? Cranking the engine and starting the engine will do the same thing, they both turn the engine. How is the motor is turning off the starter motor instead of it's own power going to end any better if it doesn't have enough lubrication??
hey,im no engine master. I just know there's more than one way to skin a cat.
That's just my understanding of the method. and isnt there a significant different in just cranking over as opposed to actually starting the engine?
If you change your oil every 5,000k why would you need to clean it ? What about your oil filter ? Doesn't that get changed to ? If your engine is filled with sludge and carbon deposits take it apart and clean it. Alternatively, water injection setup and engine doesn't get any carbon buildup. I'll go out on a limb here and say this, in my 51 years on this planet racing and building motorcross bikes, super bikes, classic Chevy cars and in the last ten years Skylines, I have never seen anything good come of engine flushing. There is alot more to the damage you can cause with running anything other than the apropriate oil. How about engine seals, bearing failure within seconds, even just turning it over with the starter. Metal against metal chaps, not good. And for my number one disaster after engine flushing, Lifters playing a symphony of various metalic melodies.
Yeh you keep saying that but we're not skinning cats.
What is significantly different? They both turn the motor. Cranking uses the power of the starter motor to do so and then once it's running the engine can use it's own power. Essentially the only difference is the RPM.
oh yes and RPM makes no significant difference with engines now does it? :)
Dude.
It's metal on metal, without sufficient lubrication it doesn't matter what RPM your engine is spinning at. MAYBE if you were using unregulated diesel fuel or bio-diesel instead of the reformulated stuff sold in Australia, the sulfur would provide better lubricity. But I highly doubt anyone is going to use expensive B100 to flush out their engine, so you are essentially using something with almost the same viscosity and anti-wear properties as water.
Posted 19 August 2011 - 01:38 AM BY 045HOW
had a dickhead i know say to me tonight that V35 skylines have a 3.6 litre inline 6.
i said wanna bet. he said yeah 20 bucks. wham bam you know what happened.
didnt pay up. told him someone is gonna punch him out some day and left it at that cause i didnt realllly care.
Mate you are all talk. Leave the car advice for blokes who know what they are on about. SAU is for fostering good will and a healthy respect between members and the import scene. You are doing the opposite of this. I think you need to listen to your own advice pal.
:ban:
^The topic is about my blown head gasket and what I need to do to clean the engine..^
All right so what i am getting from all this is I should flush my engine with diesel....I have never done this so I don't know if it really works or wrecks things but thinking logically I really don't know why anyone in their right mind would do this..... And this is the first time I have ever heard of anyone doing this.... However if it works for people who believe in this method than each to their own, but i personally don't like the idea.
From what I have learnt over the years engine flushing should be done with proper brand name engine flush oil additive from Martini or something and should only be done on brand new engines to avoid any build-up of shit throughout the engines life.
I asked the question hoping that someone who builds these engines could give me a straight and logical answer.
As far as I can see, after I remove the head I will need to check the bores for rust and remove the oil pan to check the condition of the bottom end. If there is any rust present and/or the whole engine is contaminated with water/oil sludge then it will have to be stripped down, cleaned and reassembled.
Right?
And if you people are going to argue, please f..k off and do it somewhere else. A mature discussion would be preferential. Yes we don't all agree with each other but we don't need to degenerate ourselves to bickering, name calling children.
Sometimes rebuilding or even inspecting the bottom end isn't an option. Sometimes (when broke or toolless) I have just cleaned what I could from the rocker cover and valvetrain assy with a rag. Then after fixing the head gasket I have put cheap oil in. Then having gone for a drive, it is essentially flushing the oil/water emulsion out with cheap oil. Do this once or twice before putting your good oil in. Cheap oil is only about ten dollars for 4 litres. This may not clean out the hydraulic lifters tho as the holes in them are pretty small. Mate it all comes down to what you can afford and what tools are at your disposal. If you can, pull it down and clean it out and reassemble. If you cant then an oil flush may be a suitable option for you. As previously mentioned there is a good chance that the bottom end copped it from the watered down oil. If you can hear it knocking after new oil is in then you are up the creek so to speak. If there is no knock then don't worry about it. Yes your engine will have lost some life but if its not knocking and there is decent oil pressure then you are home safe. Dont be too concerned about lifter noise as it will usually disappear after a time.
:ban:
So i agree on a bet with someone i know who then won't pay up when proven wrong and i leave it because i know them and aren't too buzzed about getting the money out of them and just want to have a good night. why i said someday someone will punch him out was friendly advice to him in regards to making bets in a pub/club environment.
A bet is a bet and if a man doesn't have his word what does he have?
I don't see how that is any evidence of me being an unwanted useless member of this forum.
I will admit i have been somewhat abrasive and trollish in this thread. its gone beyond arguing a point and for that i apologise as this is not a forum for petty beefs centered around beef (there are other forums for this). Lets call it quits and resume our love for the skyline :)
As far as the head goes it will be given to a shop for reco and have the face shaved and slightly thicker head gasket will be used. If i can get away with leaving the bottom end i will but if not I will rebuild it. I have a R34 neo sitting around so I may have to swap it in... I didn't want to because of having to re-wire...
Fair enough then. Its not that you are unwanted or useless but some of those comments were. Clearly we are here to support each other in our skylinelyness and should remain so. No hard feelings. :cheers:
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
