hey all... just bought myself an r33 gtst... its completely standard bar the 3" exhaust....
2 questions......
1: how much boost can a stock intercooler take.... is 10 ok?
2: and if i put a pod filter on will the spool be louder ? and flutter?
noob questions i know but u dont know if u dont ask ;)
cheers guys
https://www.sau.com.au/forums/topic/375231-someone-with-knowledge-pls-help/
unless you have an aftermarket ecu it can't be tuned.
10psi is ok for the stock cooler, but you are better off with a front mount because the stock cooler is tiny and suffers from heat soak exceptionally fast.
as for flutter, you won't get it just by adding a pod, however you will be able to hear the induction noise and bov noise better.
what do you mean it cant be tuned..you can still adjust timing and idle without an ECU and you can gap your spark plugs..that is tuning... Not that you should need to but it doesnt hurt to have it checked..
Maybe Ideally I should of said go get a dynorun but who cares..
On the street the stock cooler is adequate as long as your not driving around on redline..it is also more responsive
and what noise does a BOV make..flutter and with a pod you will hear it more so yes it will flutter a bit just by adding a pod..mine did..
Your gay tonight Mad go ride your bike...
You are no where!!
He asked for someone with knowledge, get out of this thread.
screw you hippy....my car ran 11psi thru a stock cooler and a pod and quite happily made 185kws all day everyday for years and it used to flutter when I lifted off so how am I no where ??
Maybe it is you that has no knowledge as you have offered nothing in the form of opinion other than to disagree with me..
So get outta my face
ARTZ - are the letters RET missing from the front of your username?
with a stock bov, you will not hear flutter. if the bov is blocked you will hear flutter.
the guy is talking about his skyline not a carb POS.
the stock R33 ecu can't be tuned.
you have the option of modifying it or replacing it with an aftermarket one.
or go real cheap and get a signal bender like SAFC so you can make changes to a:f ratios.
Adjusting Timing and idle and spark plug gap is tuning for a valiant.
OP - 10psi is fine (especially in tasmania) but you may come across the missfire type CUTOUT on cold nights on 10psi with no tuning and stock 20 year old coil packs.
If you want Flutter like you hear on silvias or your favourite japanese high power cars on youtube, you will need to block off the factory bov (not recommended).
I can tune my suspension but it doesnt have an ECU
I can tune my radio, again no ECU
I can tune a guitar it also has no ECU
and yes I can tune my skyline to some extent without touching the ECU..
And as tilksie said you CAN remap a stock ECU which is tuning it
are you trying to tell me I should not adjust my timing idle or spark plug gap on my skyline, because all have been adjusted at some point or another..shit should I change them all back to stock :O
Now OP obviously has limited knowledge here and all I was implying is that he has his car checked out by a professional after changing things like boost and filters. At no point did I suggest he change his timing I was just making a point that other things can be tuned not just the ECU....
when you put a pod on the the BOV air mixes with the turbo reverb and causes somewhat of a flutter noise when you back off, no it isnt Hektik BOV flutter but it is a flutter noise none the less..
But you know it all numskulls come in here with your tiny ewang in your hand and your limited knowledge of bullshit and try to belittle me.. . bring it on fags Ive had a shit week and Im just in the mood for your BS..
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
