hey all... just bought myself an r33 gtst... its completely standard bar the 3" exhaust....
2 questions......
1: how much boost can a stock intercooler take.... is 10 ok?
2: and if i put a pod filter on will the spool be louder ? and flutter?
noob questions i know but u dont know if u dont ask ;)
cheers guys
https://www.sau.com.au/forums/topic/375231-someone-with-knowledge-pls-help/
unless you have an aftermarket ecu it can't be tuned.
10psi is ok for the stock cooler, but you are better off with a front mount because the stock cooler is tiny and suffers from heat soak exceptionally fast.
as for flutter, you won't get it just by adding a pod, however you will be able to hear the induction noise and bov noise better.
what do you mean it cant be tuned..you can still adjust timing and idle without an ECU and you can gap your spark plugs..that is tuning... Not that you should need to but it doesnt hurt to have it checked..
Maybe Ideally I should of said go get a dynorun but who cares..
On the street the stock cooler is adequate as long as your not driving around on redline..it is also more responsive
and what noise does a BOV make..flutter and with a pod you will hear it more so yes it will flutter a bit just by adding a pod..mine did..
Your gay tonight Mad go ride your bike...
You are no where!!
He asked for someone with knowledge, get out of this thread.
screw you hippy....my car ran 11psi thru a stock cooler and a pod and quite happily made 185kws all day everyday for years and it used to flutter when I lifted off so how am I no where ??
Maybe it is you that has no knowledge as you have offered nothing in the form of opinion other than to disagree with me..
So get outta my face
ARTZ - are the letters RET missing from the front of your username?
with a stock bov, you will not hear flutter. if the bov is blocked you will hear flutter.
the guy is talking about his skyline not a carb POS.
the stock R33 ecu can't be tuned.
you have the option of modifying it or replacing it with an aftermarket one.
or go real cheap and get a signal bender like SAFC so you can make changes to a:f ratios.
Adjusting Timing and idle and spark plug gap is tuning for a valiant.
OP - 10psi is fine (especially in tasmania) but you may come across the missfire type CUTOUT on cold nights on 10psi with no tuning and stock 20 year old coil packs.
If you want Flutter like you hear on silvias or your favourite japanese high power cars on youtube, you will need to block off the factory bov (not recommended).
I can tune my suspension but it doesnt have an ECU
I can tune my radio, again no ECU
I can tune a guitar it also has no ECU
and yes I can tune my skyline to some extent without touching the ECU..
And as tilksie said you CAN remap a stock ECU which is tuning it
are you trying to tell me I should not adjust my timing idle or spark plug gap on my skyline, because all have been adjusted at some point or another..shit should I change them all back to stock :O
Now OP obviously has limited knowledge here and all I was implying is that he has his car checked out by a professional after changing things like boost and filters. At no point did I suggest he change his timing I was just making a point that other things can be tuned not just the ECU....
when you put a pod on the the BOV air mixes with the turbo reverb and causes somewhat of a flutter noise when you back off, no it isnt Hektik BOV flutter but it is a flutter noise none the less..
But you know it all numskulls come in here with your tiny ewang in your hand and your limited knowledge of bullshit and try to belittle me.. . bring it on fags Ive had a shit week and Im just in the mood for your BS..
    • Oh and my rear arms may need some attention too.
    • Bushings are almost done. Check the date stamp 😂 these are likely the original bushings with 27 years and 243ks on them.     Was too dark to get a pic of the worst one.
    • Porous blocks are a known issue on something like a Porsche M96, it's not really something I've ever heard of on an RB26. It's possible what people thought was a "porous block" was really a cracked block that they just didn't spot the crack on.
    • This is a controversial subject really, the whole power vs fun thing I mean And this is the main reason I got back into a MX5 Of the last few notable daily cars I've owned whilst I have frequented SAU R33 GTS-t: fun, but because I'm a idiot I modified well past a reliable fun car and ended up hating it, although that was my fault because I tried to have a daily cruiser and race car all in one, the family called it the sometimes car, because sometimes it was working, sometimes it was broken, gladly sold it NB MX5: brilliant car, thrashed the Bejebus out of it, but, again, was stupid and deleted the air con, power steering and stripped the interior out, whilst still fun, and reliable, and super cheap on consumables, it was not a fun place to be going on long cruises, I did love it, but basically every family member hated going anywhere in it, sadly sold it 2015 WRX STI: soulless thing that looked like your average Kia sedan and had that horrible boxer engine with glass ringlands, the family did like it though, that thing was one of my stupidest purchases and I still regret it 2017 Toyota 86: 😪 if I didn't crash it, I would probably still have it, it was a fun little thing, even with that horrible boxer engine, the family did like it, the only reason I didn't get another 86, or, BRZ was the boxer engine, I should have learnt after owning the STI, but I'm a idiot VX SS: great cruiser, fits the whole family, and was fast as.....in a straight line, but a big fat thing, so no enjoyment throwing it around corners, the family was unimpressed with the whole boganness of if, but they did admit it was a comfy place to sit on long cruises As for the NC, I feel it is perfect for what I want, or need out of of a car, whether I'm cruising the Hwy, back roads, twisties or peak hour traffic, the Mrs doesn't mind driving it either, or cruising in it as well, although she does bump her head of the roof nearly every time she gets in, which is farking hilarious, and the kids love taking it for a thrash as well So basically, I've had constantly more fun, and way less headache and heartache, both on the track and on the street, in low powered cars,  go figure.....LOL One thing though, the Mrs has stated that the cams have made the exhaust sound much louder, which they have, but it doesn't bother me, in fact, I actually like it, but, to negate any future comments from the Minister for War and Finances I may look at some changes to the rear muffler set-up to drop the volume down a tad to appease her when we are out and about in it
    • You will need to extend the turbo inlet pipe somehow, which could/might be done with silicone/rubber pipe, but might need steelwork, depending on your intake. And you will need to change the pipework on the outlet in teh same way, but this is more likely to need steelwork.
