Hey guys i am buying a garrett gtx3071r .70 housing for my gtst i originally bought (paid for) a hks 2835 kai but hks cant tell me when i can get it and ive already waited over a month for my turbo so im getting a refund for it :down:
just wondering if anybody has played with 1 on an rb25 and knows how responsive this turbo is????
what sorta revs to make 16-18psi???
And if anybody has what kinda power and torque can i expect? (based on personal experiences of course) haha!
Id like to hear your experiences with them IF THERES ANYBODY OUT THERE??????
CHEERS
:thanks:
https://www.sau.com.au/forums/topic/375232-garrett-gtx3071r/
Thought so. Apparently those "bolt-on" housings are not very good for power. Native garrett housings are better at making numbers. X3071 is a 300-320kw turbo, in a 0.7 bolt-on housing it'll make something in the region of 260-270kw. At this power level you're better off with HKS 2835.
Norm .63 or .86
They are .63, .82 and 1.06 a/r mate.
Edited by Legionnaire
I would with a pro S kit but you cant buy a new 1 anymore and at this stage from what i read the Kai kit isnt producing the numbers but im not that concerned about numbers im after good usable responsive street power and i do believe this turbo should give me that and i cant wait any longer for the hks kit lol i want that extra grunt now lol i outlayed $2600 on july 9 for a turbo and still cant get 1 for who knows how long
so the garrett it is :turned:
Well, I don't know what numbers you're after, but by the sound of it you'd be satisfied with 260-280 kw.
Maybe you should consider putting something from the GT2871 range put inside bolt-on housing instead of GT30 family?
Why is that wolverine? How do I know which is the AVO housing? Yeah anythin over 260 id be happy with. Maybe thats why the 2835 kai isnt makin the power of the pro s kit cause of the factory bolt up and no dump pipe?
Anything that bolts up to the stock dump pipe is a compromise for the 60mm turbine. There has been disappointment from these housings in terms of their power they make at the top end. So while you feel like you are saving some money on the front end you may end up with an expensive lesson if the results aren't what you want.
The GTX3071 'on paper' will make similar power to the older 76mm GT compressor but history has shown that the AVO will probably max out before the compressor has done its best.
The ARR is just what it sounds like and area radius ratio so there is not much joy in comparing the 0.73 to a garrett 0.63 or 0.82 GT30 framed ARR. The 0.73 seems to flow less than the 0.63 (The Mafia has done more to max out a 0.63 than anyone if you search for it).
I think you will get better results if you suck it up and change dump pipes and use a native garrett housing.
Hypergear results recently are showing some really good results that are very similar on paper to HKS2835ProS, plus the Kando Dynamic turbos also are producing good numbers at great prices but also require a little bit of fiddling around, like a Garrett turbo, the first time you install one.
If you are committed already I would ask if you can change to the Garrett turbine housing instead.
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
