Thanks Dale yeah its what i do for a living mate but i would like to start doing more car stuff though as people tend to appreciate nice pipework under a bonnet more than in a factory haha hopefully ill get it sorted this afternoon and get it on the dyno sometime this week am keen as hell to push the lil GTX and see how many horsepowers she is good for
Looks like you're pretty handy in the fabrication stakes there Mick. Well done, now get into running this thing up with some boost into it. :)
Looks like my car wont hit the rollers till Friday night now id say :whistling:
Gives me a bit of time to get my pressure test done and weld in my point for the boost control pinch.gif
Hoping this turbo has more than the 320kw that some have predicted and considering that it made 312kw with boost pissing out of it while it was trying to pump 22psi down her neck so im hoping to see 330kw at least! Or maybe im dreaming haha but bring on near 350 i say!:thanks:
I reckon 335rwkw @ 25psi plus with all the problems sorted out :P
PS your pipework looks awesome. Wish I could do that!
Id be happy with 335kw lol hoping this pipework helps boost and throttle response as i think those boost leaks may have been hindering my response
Thanks Justo keen to start doing more work like this i enjoy it :thumbsup:
Hows ya ride coming along?
Thanks mate yeah bit the bullet and got rid of that ugly crap haha for sure mate always keen for a chat with a fellow enthusiast :)
Looks good Mick.. so glad you did away with that half peeled spongey crap piping.. Ill probably be working or hanging out at unigroup on friday arvo so be sure to say hi!
Not much progress unfortunately, crank is back at the crank place getting the crank collar fitted. Should have done it in the first place. :pirate:
Hey Mick_o, are you still running the "small can" 14psi actuator, or did you end up changing to the 18 or 19psi big can one?
Still running the 14psi can mate might try getting the big can this week actually forgot all bout that lol
Thanks sarge thats not actually a bad idea! Never even considered running it that way as i had my mind set on shortening up that pipe as much as possible but i like the idea of keeping the pipework outta the heat i think what ive done with my pipework would be less prone to heat soak as im nowhere near the radiator and there is less pipework directly over the top of the engine which should help keep intake temps down imo
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
