Thats a pretty good wrap im happy my work is loved Steve o haha :thumbsup: my car is just my weekend fang mate i live near the hills so i go playing up there. I wanna start doing some motorsport driving as such soon though :thumbsup:
May have been haha!!
They rate it out there too, I think the term used was "pretty fkn shmick stainless work" from memory
Once it's tuned, what sort of driving stuff do you do? Trackdays? Hillclimbs? Motokhanas? Drift?
LOL Dont make that joke.. 9 out of 10 Nissan accidents start off with 'watch this bro'... This is a very 'watch this' time for old Micko lol
the other 1/10 starts with "ill just try it once more"
There is the end result gentleman im STOKED with the results out of the baby of the T3 family just came back from a quick fang and HOLY SHIT it now just frys 2nd and when you hit 3rd it just DOES NOT lay off i actually came back in with the adrenelin shakes haha :worship:
I did live to tell the results and lucky there werent any bro's to watch this hahaha :nyaanyaa:
Whether i become another skyline statistic remains to be seen yet lol
I dont plan to be a temporary citizen at this point in time :thanks:
Only 30hp shy of my T67 on a dyno dynamics dyno and by the looks a fair bit better down low :thumbsup:
Makes me wonder how one of these would go in external gate form >_<
PS. Take a better picture of the graph, I can't see shit down the bottom haha
Edited by SimonR32
Very stout result Mick. You've got to be pretty chuffed with that. My estimate was well shy of the mark, thought the manifold would have become a problem for flow around 320kW.
+1 for graph with a readable scale (rpm on X axis if possible)
+1 also for a look at the torque curve please.
+1 for torque :D im salivating at the thought of it. No really, i am.
This was done on E85 if i read correct? (saw it mentioned earlier in the thread..)
+2
+2
Thanks Lithium yeah exceeded my expectations mate and the power comes on sooo strong its an absolute hoot to drive :banana:
Awesome result, alright - gotta be happy with that! Looks like a wicked power delivery... must be awesome fun :)
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
