Hopefully its coming soon mate he did take the wheels for a spin today so hope he hands his essay over on time lol. I think he didnt mind it aye :whistling:
Where is Jezzy boy's essay after driving Mick O's car? Or have i missed it...
He did say somewhere that he will write a sentence about it tho.. :wink
Nice result Mick O, how long before it gets wound up? :whistling:
I just started modifying the stainless 0.82 rear I bought, I was planning to fit this to the GTX3071 but it looks like I have sold the turbo as a kit so it will be bolted to a GTX3076 now. The price has really come down on them lately, $1300 delivered is bloody cheap imo, and the stainless rear housing was only $250 shipped, or $350 with the vband flanges.
The Chinese knockoff Tial housing looks to be better quality than the my 1.06 Tial one which surprised me. Now to hack it up. :)
Thanks Scotty haha she gets wound up alright now :thumbsup: The staino housing looks the goods mate & $1300 is a bargain! How far off is the 76 upgrade mate?
I should have it together in a month or so mate, its about three days work to replicate the existing piping and fit it all.
I have a goal of 350awkw through the auto, not sure if it will end in tears but I have a spare engine and trans now as backup.
Sounds like a plan scotty ill be sure to keep an eye out for your results mate good luck hope it comes together sweetly
Sorry Micko. Was at dinner and then the movies.
I have to say i was very impressed with the power delivery of ur setup. Frys the tyres and pulls hard at the same time. Snaps through the rpm very quickly. I did a 4th gear low rpm pull just to the see when it came on with some load, started pulling around 3400 and was on strong at 4000 before backing off due to the speed limit ;)
Oh yeah did u tell everyone that u stalled my car when u were driving HAHAHAHA :P
All good buddy thanks for the good review and the drive of ya beast even if i did stall it glad it was only in front of you and not EVERYBODY back at the shops hahaha! Liked the way you made those quality nankang tyres scream their guts out i could hardly hear ya 26 over it and i was at almost 6000rpm haha
Dont post a video unless its full throttle, its misleading to see something that isnt 100% of its ability :thumbsup:
I think the G4 CEL can be set to do different tasks.. Normally the CEL is for knock, you will have to ask Yavuz what hes set the CEL to do on your G4.
Thats true dude but not many places i can do that tbh gunna give him a call see what he says :whistling: still gunna post it though haha still gives the guys an idea of how she goes :nyaanyaa:
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
