basically, they use an Idle air valve, super rich mixtures and 0 deg ign advance
Idle valve lets enough air in to keep the fuel burning, super rich and super retarded means the exh valve is open when it ignites.
I thought I read somewhere about the missfiring.... that they didnt fire 1 cylinder out of 4 combustion cycles or something like that but cant find that info now only what your saying zebra.
Must have been dreaming that day lol.
but anyway, the only way I could see it working is having a Power FC pro with launch control (or another ecu that supports this) setting your launch control to a certain RPM and retarding the timing in those cells.... an RB will not push a turbo at idle
I re-routed the wasegate lines on mine 2 months ago, with boost pressure helping the spring. The gtx is pushing 30psi in the midrange now, falling to 25, not bad considering the Turbosmart has a 1 bar spring. It was road tuned so I dont have a new graph but the power curve seems flat from 4k to 7.5k. Exhaust temps in the manifold are very low, I havent seen more than 700 degrees and that is on lean cruise.
Very happy with the Garrett and i'm amazed how quick it can spool to 30psi when I drop back a gear. Its absolutely silent too, great stealth setup.
That sounds more like rotational idle
Used to help cool the engine off after a hard run
I dunno where I was reading about whatever it was hey, i thought it was why the rally cars sounded so rough when they anti lag on the start lol
No idea what I was actually reading then
Missed my spot last week to get my cars final tune but hoping the end of this week the tune will be finished and ill have a dynosheet for you guys to pull apart lol i connected my rocker cover breather into my suction line and i pulled the aac valve off and cleaned that but it still didnt help my little idling bug though it did seem to make it start quicker. When i pull up at a set of lights it sits a little high around the 1100rpm zone but sometimes as high as 1500rpm but after a few seconds it drops down to 900 and from time to time it hunts up and down from 1100-600 any ideas where i should look next? Or could that be to do with the tune now since i hooked that breather line up?
Any updates?
A vacuum leak?
Did Jez manually check your idle? If not then disconnect the TPS and adjust the idle closer to the value set on the PFC.
Try 30-40 degrees retard and a bit more fuel. Its the ignition event with the exhasut valve open that cause the turbo to spool. The idle valve is required to stop the engine rpm from dropping too much.
If you did nothing but retard the timing you would still get 95% of the benefit of anti lag - hence it is the most important variable.
My cold start values were f**ked on my nistune, meant zero ignition advance, I could build ~1psi in idle at 2500rpm with about half throttle.
Would get massive compressor surge and 5psi+ trying to cruise at 60kph with a 250kw highflow.
Havent checked for vacuum leaks yet ill suss that out tomorrow arvo hopefully. yavus did tune it but we had this idle issue so i been tryin to fix it but not much free time atm :( took it for a run today and it was nearly stalling and idling bit rough worse than its ever been it runs great everywhere except for idle :@
A vacuum leak?
I will have been smoked at Unigroup prior to the tune so leaks should have been found but I would inspect all the vacuum hoses very carefully anyway.
Got my car back yesterday unfortunately i didnt get a dyno sheet because ive got a boost control issue that i need to sort out and ive also got an idling issue :rant: so the tune isnt finished yet
Yuvaz said i made 270kw @ 20psi which was a lil disappointing number wise BUT it feels unreal pulls like a freight train is very responsive and the sound is amazing!
Does anybody know where i could get my hands on some English instructions on how to setup a HKS EVC boost controller?
http://www.xspeed.com.au/manuals.php
I will second that scotty :thumbsup: my garrett is very quiet it whistles a little bit down low and thats the only trace of it really i believe it is actually much quieter than the stock turbo :whistling:
I also got a shock when i used bout 60% throttle and my gauge was at bout 18psi then i stepped on the noise pedal to bout 90% throttle and the gauge went up to near 27psi almost instantly! :worship:
Pulled my pcv valve out today cleaned it up it works fine but the rubber grommet on the other hand was stuffed when i pulled it out it broke in half :domokun: Nissan want $50 for a new 1!
Getting a new rubber tomorrow but used a rubber hose that i had and dodged it up and it didnt seem to play up as much so fingers crossed its sweet when i put the new rubber in :w00t:
Im getting frustrated cant get my tune done till next thursday now :rant:
We found a few things this arvo that need attention.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
