Fantastic result. Bit better than my 268kws. When does it feel like it's running out of puff, revs wise. Mine starts to feel flat after 5,500rpm just like the hi-flow I had from GCG. Which was a crap turbo by the way. Wasted a couple of grand on that one trying to get it over the 23okw mark. I have done 308,000k's in my car so I hope you look after yours and have as much fun as I have. Mind you, I'm on my second engine and 2nd gearbox and 2nd diff and 4th clutch, but hey, don't worry about all that. Engines are cheap so make sure you enjoy it.
A couple of tips. Replace your coils around every 140,000k's. Just replacing my 2nd set again now. You will need to replace all the relays attached to the engine loom and coils at 300,000k's or before if the car is thrashed on hot days alot. Heat is the enemy. I have replaced the coil harness just now and it fixed a little miss in the top end. Have alook at engine mounts and gearbox as well, they will let go in spectacular fashion if left with any defects from constant cicuit work. So many things to do so I'll stop before I make myself stress. :yes:
*cough* I near sprayed my computer with coffee, my gt3071 sr20 curve is nearly identical, even peak power. I won't post it as i don't want to take away from micks results as that is awesome for a .63 IW on a stock manifold. No boost control issues either which is a relief.
Out of interest, what boost controller do you run mick as i would have thought it would hit full boost a lot sooner (under 3k) based on my old rb25 results.
Your setup is wayyy different, this is bolting on a turbo, intercooler, injectors and afm to a stock setup. Not fair to compare.
Full boost under 3000rpm is ludicrous on this type of setup. Even the most responsive of turbos that hit the ceiling at 240-250rwkw cant make 20psi by 3000rpm.
It's doable. 2 of mine when i was trying to get it right on the rb25, unfortunately not showing 20 by 3k in either of these as we were battling boost control issues. On road it would crack 20psi by 3k in 4th on a flat road easily.
Same basic setup as Mick's but with a .63 and a set of drop in cams.
I heard you might be looking for a turbo, liz, I'll pm you the sr results
edit: the bottom one was boost control via the right foot so not even wide open throttle, hence the really bad curve.
Edited by badhairdave
Not making 288rwkw on 98 fuel, I dont think its possible to get 20psi by 3000rpm.
Increasing the ramp rate can move the response earlier too. Mine hits 20psi by 3200rpm (9 second ramp rate) but only makes 245rwkw on 98 fuel.
Graphs look like they are from a auto?
Here us another GTX3071 with poncams on a neo rb25det.
Pretty damn impressive for a 71 on only 15psi in the top range. Apparently the boost is wrong on the graph, it comes on a lot sooner than it indicates, an issue with the sensor having lag apparently.
Can read about it all here http://forum.nistune...&t=950&start=60
tuner was very surprised with the result as well.
Edited by Rolls
Cheers Lithium it felt quite good with the unfinished tune which it made 266kw and the little squirt i gave it last night it came on a bit sooner and felt really strong i shifted from 2nd to 3rd at bout 5000rpm but she was starting to break traction at 4000rpm lol. Ive never heard a 25 with a 3076 tbh but its quite whistly ill try putting a vid up of it on the dyno and ill let you be the judge :thumbsup:
Nice work - glad that went smoothly, nice stout amount of power... definitely not a normal GT3071R :D
Tbh without any prompting I'd have thought it was a GT3076R dyno plot, but dyno plot doesn't tell the whole story - after you've had some time to get acquianted it'll be interesting to see how you find it. Out of interest, with that 11blade wheel does the GTX3071R have the same kind of anti-surge whistle craziness the GT3076Rs do?
Im running a HKS EVC 6 boost controller dave i still think there is bit of fiddling with the controller to be done yet to help bring it on bit sooner
Mine's absolutely silent, are you sure its not the BOV leaking or something else?
Thanks Jeff i didnt go for more boost on the dyno but when my controller wasnt set up properly it easily shot up to near 27psi and started spinning 3rd gear at bout 90km/h :whistling:
Great work Mick!!
Did you try going any higher with boost just to see how the turbo handles it? My understanding is thats where the GTX shines.
Hey Gary cheers for the tips mate they are duely noted :thumbsup: to be honest even when the tune was incomplete it felt like it pulled all the way 7500rpm and unfortunately i havent seen lotsa revs yet.
Id actually like to thank everybody in here who gave me advice on my setup because you guys really did save me money and steered me in the right direction with my car! :worship:
Im pretty sure its all induction noise scotty well i hope it is lol! surely the 4 or 5 lads that were all over my car while it was on the rollers woulda picked up on it :rolleyes:
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
