You forgot the colon in http://
http://s1229.photobucket.com/albums/ee463/mick_o1/?action=view¤t=video-2011-11-02-20-43-43.mp4
you just need to copy paste the link lol. Control + V in the address bar, then press control + V in the textbox and press post = win! :)
Edited by Rolls
Lol thats what i done mate but didnt work :wacko:
I just came back from a cruise on the M4 and in top gear cruising on 110km/h i slowly wound on the juice and my car was making a squealing noise and boost was only around 10psi when it was making that noise :domokun: any ideas any1 doesnt do it in any other gear????
It might be a compressor surge? Really high load low rpm the turbo may be pushing more air than the engine can swallow
if its compressor surge you can try tweaking the tune if it doesnt do it by much.
otherwise you basically have to try make it lazier onto boost, so either lower gain settings or lift your foot slightly through that area.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
