GT3040 which is old school, 18psi @ 3900rpm. Boost is pretty irrelevant as ultimately it is all about how much airflow the turbo makes at each rpm level and therefore how much torque/power at that point.
The 0.82 has a nice linear delivery.
Thats prob too laggy for me plus is wheelspin gunna b an issue with more than 270kw on the street? Its great to have a large power figure but getting it to the ground is the other issue. Ive gotta kaaz 2 way and quite a good handling setup
Yea, as he said, the 3040 is old school and it's also larger then what you're planning to run. I would expect a gtx3071 with .82 to be on full boost more like 3400-3500 rpm. as said though, if you want a bolt on solution for 250-280kw, it's getting hard to beat the current hypergear offerings. Both on price and performance.
Mick the car makes plenty of power down low, it is not wheelspin city.
There are better turbos out there today than the GT3040 I have but it produces similar numbers to many GT3076's. I have owned and driven cars with stock turbos, bushbearing stock rebuilds, GCG hi-flows, HKS GT-RS, HKS 2835ProS and looking at a dyno plot will not tell you everything about how they are to drive on the road. When the engine comes out I am changing to a twin scroll GT3076 just to see how much (if any) better it is than what I have.
DaleFZ1 back to back tested a GT3076 with a HKS2835ProS and he reckons there wasn't much in it but preferred the GT3076.
Any turbo that can make 180-200rwkw at 4000rpm is going to be a very quick streeter regardless of what boost it is running...
Yes always the same debate over the gap in Garretts turbine range - meaning GT28 to GT30 and theres little feedback on the GTXs so far .
Theres also been uncertainty from those using the original GT3071Rs with some thinking in 0.63 A/R turbine housing form doesn't deliver while the 0.82 T housings seems a little laggy .
As Mr Woolaf mentioned the Mafia had some good times from his GT3076R/0.63 A/R turbine housing though he did use water injection to keep temps in check .
If I was going to use a GT30 based turbo on a street RB25DET I'd look for the mid or 52 compressor trim version of the GT3037S/GT3076R (same thing) and put the 0.63 A/R Garrett GT30 integral (internal) wastegate turbine housing on it . The 52T GT compressor is good for I think 90% of the 56T versions airflow and has a better comp map IMO . These like the 56T version have port shrouded compressor housings on them which removes ALL the surge issues people can have with responsive while powerfull turbochargers .
My take is that if turbo (turbine actually) lag bothers you , at all , use the 0.63 A/R turbine housing because thats whats going to bring the thing on reasonably early so you get to enjoy you car/engine without having to rev the tits off it all the time .
At the end of the day if you can turn and burn the tyres almost at will it doesn't matter how many killerwasps the dyno counts because you have more power/torque than traction anyway .
I have a 52T GT3076R in 0.82 IW form I bought a few years ago and I think GCG and possibly Garrett here in Sydney keep them in stock these days . I'm not so sure you'd get any great discounting from either of them but sometimes when you want things a little less mainstream you cop a premium . You would have to call and ask for pricing . I'm only keeping mine in case I built a dirty 30 though I have no immediate plans for that .
Personally I would not limit myself to the std dump pipe configuration with a GT30 based turbocharger , they work well for GT28 based turbos or those using the VG30 OP6 turbine housing but they lack flow potential for a 500 Hp capable turbine like the GT30 one .
Its not the end of the world to buy or make a dump pipe for the IW GT30 turbine housings and the easiest ones are the open or bell mouthed ones . Being a bit bigger in the turbo flange means its probably a lot less fiddly that doing the RB or even the T28 style ones .
I'm not that keen on the store bought divorced ones for these housings because some mobs cheap out by trying to hole saw two holes through the turbo flange and the gates outlet is the wrong shape and the pipe small . I think to make a divorced one properly means making what some call a "shell back" something like the HKS GT Pro S ones or the Megan Racing ones for Evos . Its a lot more work for something that may work if NASA frigged around with it for a week with lots of flow bench testing , $300,000 dollars later ... Bellmouth is simple easy and works well enough IMO .
Anyway this is what I'd do for a road RB25 where power and response is the requirement . You read here all the time about people who went with big turbine housings or bigger turbos looking for the big top end power numbers but they hate how their car now drives . Sure it makes the numbers but buzzing the engine everywhere in low gears so the thing gets going when they prod it gets REALLY boring REALLY quickly .
What I think the vast majority want is more poke starting not much if any higher than what the car had originally and it can be done if they think a bit conservatively . If you can live with 260 Kw maybe a GCG Hi Flow or a HKS GTRS is enough and it sounds like both would be more responsive that just about any GT30 based turbo .
If anyone you know has these can you go for a spin with them ?
Also I know others do good Hi Flows but its hard to impossible to beat the reliability of ball bearing centre sections , if you're going to work a turbo hard a properly designed ball bearing centre section stands up to radial and end thrust loads better and with less friction .
I'm in now way insulting plain bearing Hi Flows but people have to understand that plain bearings are less costly than small high temp and speed capable ball bearings so its a costing issue . If the price was the same no one would sell plain bearing turbos , its the extra for BB ones that some cannot afford and we all have to live within our means .
My 2 cents , cheers A .
Edited by discopotato03
Anyway this is what I'd do for a road RB25 where power and response is the requirement. You read here all the time about people who went with big turbine housings or bigger turbos looking for the big top end power numbers but they hate how their car now drives. Sure it makes the numbers but buzzing the engine everywhere in low gears so the thing gets going when they prod it gets REALLY boring REALLY quickly .
I actually don't see that many threads on what you said in bold on here, if anything I've seen more people moving up from high flows and GT2x based turbos to full GT30s. I personally moved to a .82 from a .63 56T GT3076R and never looked back - I found it incredibly easy to sell off too, there was a few people who had dibs on it (if I ever sold it) after being in or driving the car so I'm not sure which combination you are referring to as there are few people here running GT35Rs or bigger with stock engines.
100% agreed.
In practical terms I'd doubt if either a GTX3071 or the "old spec" GT3076R 56T fitted with the 0.82A/R turbine housing would vary enough to notice in terms of spool, or top end airflow capability. There may be some slight difference in transient response feel (surely the lighter/smaller impeller spins up quicker into its speed range), but for me it's most likely a marketing driven release to pre-empt the EFR series release from BW.
And an RB25 with GT30 rear end that's producing 17-18psi around 37-3900rpm, and holding torque well up towards 6000rpm does feel quick and behave in a linear/predictable fashion. The difficult part is being honest enough with yourself to know whether you can access and use that sort of torque delivery or otherwise stick with a GT-RS type/size of delivery and response.
Hey Dale, how you doin' ?
Mick o,
I have the 3071 .82 rear housing with genuine 60mm turbine wheel. It hits full boost (gear dependent) at around 3,200rpm. But there is a whole lot more to it than that. It is already on the verge of wheelspin well before that in the 1st two gears. Wolverine, Lithium and Dale, like me, have had our cars for some time, and they are correct, the .82 housing brings power on in a controlable fashion. I am now at 268rwkws. Please dont think anything but the Garrett rear housing and 60mm turbine is any good. The limiting factor is the compressor. At 18.5lbs boost I'm at the limit of my power/torque production unless I go cams. But if I do that I just get all that boost but earlier.
Now, the GTX3071, it supposedly has more compressor left in it, I tend to agree. Lighter wheel, hmmmm, cant really see more than a bees dick in it. So maybe 10 more kws, same power curve. Gor for the old 3076 or if instant boost is required go the GTX3071. Either way you'll be better off than me and I'm happy. If you need a hand tuning, Call on any one of us. Please tell me you have PFC or better. Dump pipe is easy. Air filter to turbo no worries. Long term you'll be happier.
I really do appreciate hearing all your experiences with these turbos guys :thanks:
its been good to campare all your experiences with different turbo kits
since it seems that nobody has posted anything about how this actual garrett setup on an rb25 performs on the dyno and how it feels on the street has made me buy this turbo cos to me in theory it seems like id get more power with this turbo than the hks 2835 kai (which i originally purchased) and has made on other guys cars in here with only minor if any loses in response.
ill get all my facts and figures together and feel how it drives and share my experience with you guys hopefully in the next couple of weeks :worship:
Its gunna be interesting to see whos theory comes closest to how this turbo actually does perform (in the real world) since nobody has any personal experiences with this kit!:banana:
Tao has accomplished 320rwkw from the SS2 which does not cause wheel spin in gears, between gears though, is a different story haha.
:thumbsup: Appreciate the offer mate ive actually been chatting with Jez from DVS tuning on helping me with the install and playing the AFR'S on the road a bit and get her running with the Z32 AFM and the bigger injectors( so hopefully i can COAX him over) haha!
your set up is making boost quick i couldnt imagine my Gtx making boost sooner than tha thot???
My car is running a nistune and i hope the gtx makes about the same power you have!
i would be interested in comparing the differences between our cars with the different kits too!:thumbsup:
Mick o,
Haha nice!:rolleyes: 320kw its a big juicey number but how long is a unopened rb25 gunna last with that kinda power? I have heard that the 250-270kw zone is the safe power limit? (so to speak)
Its a daily driver which I baby, never track and enjoy. It should last a while. Its hardest time is probably going to be on the dyno lol.
100% agreed.
see heres a pic of mine old tech 3076 comp with the modified .64 skyline rear..
i can smash the pedal in any gear at anytime and it goes hard
compared to stock
you can almost see by the size of it its going to choke..It is still very quick on the street with full boost 19psi around 3500 and the small housing does give great response it drops to about 17psi by 6500rpm though, as do most IG and once you get in the upper rev range over say 5500rpm it just isn't as exciting as it should be.
Its making around 240kw @ 19psi which is alot of boost for not much result, but it is an old tech compressor. A new GTX one would make more but not much, 260 maybe, tangles makes 250kw ,if i played around with cams and gears etc it might make more, but I'm not going to bother as its easier to just swap it completely..
its still good fun and very driveable on the street with stock like response. The bit of extra lag it does have helps stop it form stepping out or losing traction to early, so its actually quite well balanced in an unbalanced kind of way :wacko:
I was speaking to AVO and they said they still sell plenty of their housings so someone must like them..
They are not ideal though and you dont really save alot of money doing it.. so i wouldnt recomend it..
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
    • Shit. Starting to look like a car again.
