Seriously? A bigger non ball bearing turbo being less laggier?
i take bush over balls every time.
But seriously the bush stuff is so much more hardy and the response diff is litterally negligible.
But have to say I am a bit disappointed its not making 200rwkws until around 4,300rpm which is only 200rpm better then my RB20 with a TD06-20G on 98. I am really looking for a 330-350rwkws setup that does 200rwkws at 4,000rpm.
I wonder if something like a Full Race manifold, twin gate and GTX3071R on a std RB25 would do over 200rwkws at 4,000rpm?
Yeah I noticed that with the higher resolution one as well, I'd expect a normal GT3076R to at least match that on E85. A setup I think would be unreal on an RB25 would be a 6boost manifold, wastegate and a FP GT3076R HTA... probably very hard to beat.
Argh, who starts a dyno run at 3900rpm haha... Makes the curve look so much better than it actually is!
Probably not as good as I thought it was down low compared with a T67, actually may be a tad on the laggier side.
But in saying that it's a very impressive set up for a low mount standard inlet and exhaust manifold set up
100% agree.
Now you see that nothing actually happens before 4000rpm - It's nothing remarkable IMO.
Really? Its 25psi by 4000rpm, starting at 3900rpm means the turbo has less time under full load to overcome inertia
Run starts at about 17psi which shows motor was loaded up before the run
It's not exactly apples with apples, internal vs external gate with an aftermarket manifold
17psi loaded at 3800rpm-ish is actually not that flash, loading a GT3076R against a dyno like that (depending on how long you load it for) you can easily hit 17psi by 3500rpm.
I've not been in or driven a car running a GTX but I'm feeling more and more like they aren't doing anything that the previous range did, GTX3071R = GT3076R, GTX3076R = GT3082R, GTX3576R = GT3582R. GTX3582R, well... they have made some huge power but there are plenty of other outfits who have been upgrading the GT35R compressor wheels which cost less.
not really a very good dyno sheet to compare with, need to start it at 2000 without loading it up for 30 seconds before hand.
You do realise something as simple as dyno ramp rate will affect perceived response on a dyno...?
God you can be a wanker nismoid, you know what I mean.
Start it at 2000rpm like a normal dyno run, eg on appropriate load settings, not holding it on massive load so that it doesn't increase in rpm pre spooling the turbo. If you start it at 4k you could have been holding it there for 5 minutes before hand, we don't know. At least if you were to do that at 2k it wouldn't cheat the dyno result too much assuming of course the correct ramp rate for the rest of the run.
Edited by Rolls
But bringing people back to reality for a second! Its a 335rwkws std RB25 with a bolt on turbo! That is mega. Perhaps a gate, manifold or other combination may be a tad punchier, but show me a single bolt on turbo that will match this setup???? I haven't seen any? Would be pretty mint, stock looking setup if his pipes weren't so sex when you open the bonnet.
Wow hasnt this got some bad press now?! It went from wow nice results mate to meh thats not that crash hot HAHA! :blink:
I dont understand any of the dyno jargon you blokes are carrying on about lol!
Its just a sheet showing how much power it made FFS! To me it doesnt give a true representaion of how my car drives in the REAL world my car is far from dead under 4000rpm even if thats what a line on a piece of paper says to you in fact the car takes off like a dog shot in the ass 3800rpm in 2nd gear all the way to redline 3rd gear is on instantly if you stay hard on it in 2nd gear off boost its torquey as hell and feels as pokey as any big Falcodore 6 cylinder which is very impressive for a 2.5L imo... Yeah probably doesnt come on as early as alot of turbos or the GT3071 that it replaced for that matter. I dunno if my eyes deceive me or im not reading the dynosheet right but is 25psi @ 4000rpm on a factory manifold with an internal gate laggy?
My car is far from an exotic or by a big $$$ setup its a basic bolt on package on E85 nothing special really i woulda thought :ninja:
Now dont get me wrong this is not me getting defensive to the constructive critisism from you guys as im stoked with how well my car goes and how well it drives on and off boost is a credit to the boys at Unigroup engineering and 450hp isnt too shabby at all i reckon :banana:
I just feel some guys get caught up in the dynosheet too much as opposed to how it feels to drive on the road which is where it really counts......... Thats my 2c anyways haha
Jez is gunna be taking my car for a run this weekend so ill put the hard word on him to do a little write up and give you guys his opinion on how my car drives lol im sure as shit hes driven as many different turbo combinations on a 25 as anyone in here :thumbsup:
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
