It is an interesting result, falls over quite early for a cammed RB25 with a GT3076R though - wonder if there is a restriction somewhere or something. I would have expected a bit more, but I guess we have fairly few internally gated/stock manifold E85 results to work from.
I wonder where you've seen that.
The GTX3582 AR63 isn't a good choise. It produce exact the same power as a GTX3076r but, came on 500rpm later! A GTX3582 Ar 0.63 doesn't make sense because the turbine housing is the limited factor! And with a Ar 0,82 it is very much to laggy. I say that with experience, because i've had a gt3582 Ar0.82 on my Gts-t with a external screemer pipe :-) ther's nothing to 5k rpm and than "bangggg!!" funny but not very useful.
Is there nobody who ha experience with a gzx3076r on rb25det?
I have gtx3076 .82 on my rb25...
  • 1 month later...
The RPM is calculated though, its usually not accurate from what I have seen, how can you know every car's ratios anyway? If you can't work it out from the graph i'm sure someone will have a guess for you, without seeing the sheet I can say it would probably come on hard around 4k.
My tune today didn't pan out, speed cut and a slipping lock up clutch ruined my chances of a good result with the 71. I will be back on the weekend with the SLD back in place hoping for 350kw.
The gtx3076r is similar in spool, if not a small margin worse, than the gt. The gtx really only comes to life once you start throwing lots of psi at it. Although.. Im sure a true twin scroll housing+manifold would bring the spool back to baseline.
Any luck with the tune Scott?
I was seeing over 300kw in 4th at speed cut which I guess was around 5000 revs. Once I wire the SLD and get rid of speed cut again I will be able to see the outcome of my fine tuning. The MAC wastegate solenoid is working a treat now, it held a flat 25psi from what I could see. I will ramp it up on the weekend during the next run.
It has external gate, AVCR , 256cams, cam gear, maybe a 50/50 ethanol blend
id be happy with near 200kw at 4000rpm with 18-20psi
Why 50/50? how far away is Warwick from you? (or is there a Caltex up there?) You will see better gains from just running United e90 with none of the cold start issues we see down here...
You should come close, perhaps around 4200 revs? That's my guess.
well im doing all this on a tight arse budget and getting impatient, some parts like the HD clutch, walbro fuel pump, and now rear muffler with silencer may fail before it reaches 300kw
So i guess for now ill have to see what happens on the dyno, im thinking even 280 would be great,
50/50 blend is another cheaper option.
Edited by SliverS2
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
