Just got back from the Liberty club dyno day at Edge Motorworks, i'm buggered after strapping 23 awd cars down to the dyno but what a great day.
Anyway, my winning result was 341.1kw at around 23psi, just shy of the 350kw goal. Cihan (my tuner) decided not to push it further as the compressor was out of flow again and he doesn't want to see me brake it for no reason. Very happy with the result though, the car is unbelievable to drive and it's a stupidly responsive turbo for the power output. Also good to hear that the Edge dyno is comparable in readings to many of the other local tuning shops.
Shame I didn't get the torque graph, you can plainly see the compressor flow dropping off as efficiency goes out the window.
Of course mate, the closest contender retired as his Cosworth 30k engine was running stoich at wot. :)
Why are the manifolds an issue Zebra? HKS thought they were good enough for their 350z 3037 kits...
I would love to design some killer manifolds one day but I may have to go twins and rwd before then. The box can't handle much more torque than i'm currently throwing at it, Kewish Auto said it MAY handle 250kw if i'm lucky. lol. Looks like i'm just a lucky f*kr. ;)
True it is only a 3071, so I guess it's pretty much at its limit already, manifolds won't yield much benefit without more turbo..running the sugar juice is no doubt aiding alot in keeping it cool anyway..
So front mount twins it is then :banana:
If anything Scotty, it'd be the crossover pipe to mod first IMO.
Comparing the one in the HKS kit to the stock item showed some differences- mainly being the stock one has a big restriction from a press bend.
If you look at the pipes area it's still much bigger than the turbo nozzle so I doubt it would make much difference, It may perhaps keep the gas speed up if anything, I think the crossover pipe is too big.
Scotty what rev are you at when you hit 200kph? IE when the dyno run ends?
The graph shows boost threshold as between 130 and 150kph. So if you were at 6000rpm @ 200kph, your boost threshold is after 4000rpm. If you were revving it harder, your threshold is also higher.. Say it was revving to 7500, your talking about a minimum of 5500rpm for full boost (on that graph).
Is that a misrepresentation of the dyno or is it not as responsive as I had imagined? Mick's is on a lot sooner I believe.
Its a little hard to guess as the dyno has a 200kph speed restriction and I have no idea what revs it was actually at when it hit that (Cihan may know). There was still more revs left in it though, I run a 7300 soft limit.
Also, the ramp is misrepresented as he cant stomp on the pedal, if the car isn't doing over 80kph and he doesn't ease the throttle on it will kick down into 3rd, and that isn't good at all. :blink:
Boost hits hard at around 4k on the street just to give you an idea, but there is still plenty of power at 3500, perhaps 200kw? Just guessing. I wish I knew how to drive the Fcon, I could log it for you.
Ahh I c.
I think there is a way to lock them into gear, like you can lock the torque converter. I'm no expert though, and that does provide some decent insight either way.
Bloody auto's! lol.
That run was with the converter locked but you can't lock it in gear as far as I know, perhaps I can cut the CAN line so it doesn't get the kickdown signal?
That said, what manual box would handle this torque for an extended time (not that I could fit one), and how much would a suitable clutch cost me? I guess its doing pretty well for the soggy box it used to be...
I think I read status saying to use a manual clutch and fly with the auto box to increase durability. You only need to use the clutch to take off.
If you want a tough 5 speed box you should look at the R154 (5 speed, under 2k) or V160 (6 speed and very expensive) boxes. Theres a company called dellow engineering who can make a bell to suit that box from anything. The R154 specifically is really short and can be fitted with a remote shifter, so you can fit it in just about anything. It is pretty fat tho, but It cant honestly shadow the auto... Or atleast I hope.
They can hold the power, no worries. Like I said also easy to work with coz of how short it is and the remote shifter. Cant comment beyond a guesstimate on the price of a clutch, I dare say the better part of a grand as a starting point.
  • 3 weeks later...
Mick was kind enough to hand over the keys yesterday for a drive around the block, then around the corner and a bit further haha.
Can't believe how well it goes for the money spent (eg stock motor still, still OEM plenum etc).
Sure it's fun with your foot down but it's surprisingly tractable just cruising around!!! This car does not need big revs to move along. You can change gear at 3000rpm and it's moving along easily at traffic speeds for example. Of course when you want to go quick it's not long at all till meaningful boost and off you go
Plus it has to be the cleanest 33GTST I've seen in quite some time.
Don't change a thing Mick.....well maybe the RB30 bottom end haha
Thanks for the kind words Steve O think i will change the brakes soon though haha!
As for the 3.0 bottom end.................
Im writing to Santa bout that because i have been a good boy this year so see how i go huh? :P
It was very quiet actually. The only screech was the nangkang's turning :D
Those nangas are noisey bastards but thats Steves fault ;) I have the right filler wire for those pipes at the workshop and a good plan of attack too mate :thumbsup:
    • I've owned a few scooters over the years, a Vespa PX oil burner was my first scooter, followed by a few others, including a little 50cc BeeWee that I used as a barracks bike, and I've had a blast on all of them, they really are the cheapest for of city/suburb transport around The only issue with scooters in Australia is lots of people look down on them due to their size,  maybe they need a big bike to make up for something else where they are lacking, unlike Europe and Asia where every man an their dog owns one, and now that filtering is legal in NSW, local traffic is never a issue Not to say I haven't owned my share of big cc bikes over the years, but they were for more blasting through the hills or Hwy riding where it needed to sit on Hwy speeds Safety wise, I ride like everyone is always trying to kill me, everyone is running a red, or running stop/give way signs, or generally asleep at the wheel, which most people are duringtheir commute, I also ride really safe, and give myself, and everyone else enough room in case I need to pull some hasty evasive actions, I've done a few rider training days over the years, which has come in handy on more than a few occasions  As for mods, there's nothing really, and yes your right about aftermarket exhaust, all you get is loud and obnoxious noises from them, like every 250-300 cc you hear with a aftermarket muffler, in saying this I did put a rear muffler from a 125 Aprilla on one of my old 125 scooters, it was horrendous and no amount of full face helmet and ear plugs would dampen that noise As for coming from the Harley, and what a overpriced POS that was, I no longer do big rides as my poor old busted joints ache after about 1/2 an hour of riding, long cruises are so much more enjoyable now in a car, so a big bike would be pointless
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
    • Nah. H2S. H2S is "rotten egg gas", which is what is associated with no cat. SO2 is equally nasty, and if you've ever smelt it you'll know all about it. More of a choking, acid in the back of the throat sort of thing. But you can only smell it in a narrow range up to about 1ppm. Above that, it irritates your mucous membranes, but you don't smell it.
