Good stuff.... :banana:
the internets he says shes says can drive you crazy...I went to the extent of buying a new turbo for mine cause for the last 4 months I havent been able to drive it.. So I sit here reading stuff to kill time and on paper full boost @ 3600 and 235kw, its not so crash hot..
Got it up and running today drove it around a bit, give it a few clutch kicks and i was having a ball, so much so i couldnt care less about the new turbo atm I just wanna drive..
just bolt it up get it tuned and I bet you will love it..then 1 of 2 things will happen
1.. you will realize it wasnt worth all the headache and expense and give up on it..
2..you will freaking love it, the bug will bite and you will start a list to mod more shit..
Busy training with air for other purposes today .
A std BB type GT30 turbine measures around 59.9 by 54.9mm inducer and exducer .
The cropped ones from memory are 56.4 by 51.6mm (84 TRIM) OR 56.4 by 53.6mm (90 trim) .
Your calls , my preference is for Garrett or HKS GT30 "T3" flanged GT30 turbine housings . The HKS GT Pro S ones need a bit more work to make the dump pipe and if you particularly wanted one of their different A/R ratios its probably worth it .
I'm not sure what size because there isn't a lot of feedback with these GTX compressor wheels .
A .
Heyyyyy?
To clarify, you gibberish speaking bag lady, your talking about your existing setup? Not a 20g result. Yes?
Heyyyyy?
haha..thought that might stir ya... ;)
thats my exsisting setup yes...its lame on paper but its still great fun to drive..
Ok ok u guys have talked me into getting the .82 garrett housing lol!!!! ive spoken to MTQ today and they are gunna let me exchange my sonic housing for the garrett unit tomorrow arvo and they have a dump pipe as well so its gunna cost me another $500 to swap housings and get a new dump pipe.......
So will the little 14psi actuator that i have pictured in here be up to the task or is that somethin else ill need to look into?????
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
