180 wanabe Posted August 25, 2011 Share Posted August 25, 2011 Well guys as some of you may have read from another post I created I have been having issued with my cars ABS SLIP VDC lights coming on the dash The problem is intermittent in that sometimes "rarely" I could do a whole drive to Brisbane from the Gold Coast without the lights coming on. Where as other times when the ABS dose its self check usually once the car has been turned on and gotten up to 10kph it will then start pumping the pedal and make lots of noises from the front drivers side whilst at the same time the speedo wont be moving or is not displaying the proper speed. The problem has become progressively worse over time I was told by the local brake shop who hooked up a scan tool to the car that the front drivers side ABS speed sensor was throwing a fault code. So I got a 2nd hand one off a 350Z from a wrecking yard posted up to me, I switched the sensor over last night and took the car for a 400M drive around the block and everything seemed to be going perfect, ABS was working and no funny noises Anyhow in the morning when I went to work I got no further than the end of the street "100m" before the lights came back on as the pedal started making its funny noises I noticed when I changed the sensor last night that it might read the speed of the wheel by magnetic fields or something as there was no COG/gear just a flat bit of metal that sits close to the inside of the wheel hub/baring I also noticed it looked rather rusty/dirty where the wheel hub/thing was spinning near the sensor so I am going to pull it off again in the next day or to and try and scrape/clean some of the crap off and see if that fixes the problem I was so pissed off after having switched the parts and thinking that everything was going to be FINALLY sorted particularly after the drive around the block. If I didint install the sensor properly one would think that the warning lights would come on straight away when the car was turned on/driven around the block Link to comment https://www.sau.com.au/forums/topic/375249-abs-speed-sensor-vdc-abs-slip/ Share on other sites More sharing options...
dodes47 Posted August 26, 2011 Share Posted August 26, 2011 Hey Sorry to hear about your woes mate. Ifeel ya I had a similar problem with my car when i first got it. When i scanned it, it reports that the wheel speed sensors are faulty. Had a mechanic look at them and turned out it was just loose and dirty. So give it a clean when you can then see how you go. Maybe the replacement sensors themselves are no good? Get the part number and post it here so i can help you look up prices. Also, if it still happens afterwards, try to swap the sensors around from left to right to troubleshoot it. Link to comment https://www.sau.com.au/forums/topic/375249-abs-speed-sensor-vdc-abs-slip/#findComment-5985898 Share on other sites More sharing options...
180 wanabe Posted August 28, 2011 Author Share Posted August 28, 2011 Might swap the sensors around and see if it makes any difference Link to comment https://www.sau.com.au/forums/topic/375249-abs-speed-sensor-vdc-abs-slip/#findComment-5989085 Share on other sites More sharing options...
black 350 Posted August 29, 2011 Share Posted August 29, 2011 i am having similar issues i have resently fitted extractors, high flow cats, and disconnected the battery so as to do a system reset and as i took off after the front wheels started to lock up but only when i had turned my steering the slip flashed than i breaked and it stoped flashing drove forward again and it happened again than the vdc was illuminated and slip also. pissing me off so much, so now i have to disengage vdc before i go any where once engine has been switched off. but if i start up and drive in a straight line the slip and vdc become illuminated, there fore no traction control on. any ideas and these sensors where are they? thanks Link to comment https://www.sau.com.au/forums/topic/375249-abs-speed-sensor-vdc-abs-slip/#findComment-5990322 Share on other sites More sharing options...
180 wanabe Posted August 29, 2011 Author Share Posted August 29, 2011 Well I not sure why your having that problem, Im thinking that I might pay a visit to Gavin wood in the not too distant future as he has all the fancy scan tools to work out what exactly is going on Im thinking that you might have to do the same or go to a willing Nissan dealer and have them plug in whatever their tool is "consolt" I think is what its called Link to comment https://www.sau.com.au/forums/topic/375249-abs-speed-sensor-vdc-abs-slip/#findComment-5990791 Share on other sites More sharing options...
