Hi all am about to own my first skyline, a 32 Gtst.
Have just come from a 12 sec 200+kw atw manual legnum and hope I can replicate those kind of figures with the 32 fairly comfortably to :)
Looking forward meeting folk on here and doing it all over again with s skyline!
https://www.sau.com.au/forums/topic/375264-new-kid-from-sydney/
Haha I'm a mechanic so plugs aren't too bad on the legnum...just like a magna really...,I'm more excited about having a nice simple rwd setup!
You think a 25 is the go hey? Not disagreeing but I might stay true to the ol' 20 and build it up...then again might go '25. I'm not looking for monster power low 200's atw is plenty for me :) if money permits though might go 25 :
Thanks for the welcome!
Edited by the_wolf
I would stay with the rb20. They are a tough lil engine and if worked on properly you will easily be able to produce that power figure. My r32 gtst i just sold had a high flowed rb25 turbo, exhaust, front mount cooler, fuel pump, injectors and a tune and made low 200's easily. Was a fun little car. Best of Luck and welcome!!!
+1 for the rb25 conversion. sure you can get power out of the rb20 but at the expense of low end power. you can get the rb25 to be knocking on the door of 200kw with stock everything but exhaust and cooler (with the boost bumped up a bit) and it will be making full boost by around 2700rpm. even with a turbo, ecu and injector upgrade you can make around 250kw and still have full boost by under 3000rpm. to get even 200kw from the rb20 you won't be making full boost until closer to 4000rpm.
^this is true but the 20 is a solid unit and is more than happy to rev its head off all day. I had a 20 with a to4e + supporting hardware with 210rwkw, was a ball in a nice light chassis. The 25 does have more scope though, by the time youve done up a 25 you could have a 26 with light mods.
Yep can totally understand the benefits of a 25 in terms of low end torque....it simply comes with the capacity. At the moment though as I e cone from an awd turbo background im going to be getting the suspension and brakes exactly how I want them and learn how the car behaves before chasing more power.
you can get that sort of power out of the stock turbo on a 25 with just an ecu (and a shortened turbo life). if you are willing to run the gauntlet you can get up to around 220kw on the stock turbo at about 16 or 17psi through the stock turbo.
Yeh I'm happy with 240-250, that's plenty for me...but I want it to be useable power, I don't know whether the 20 will have as much of a street friendly useable 250kw as a 25 would
No way in hell!
Get ready for the torqueless goatf**ker compared :P
Lmao yep I sort of figured....oh well might drop in a 25 down the track when funds allow...
To save all the to and fro with questions I have about how easy it is to swap to a 25...could someone post a link to some info? Thanks
search function is sometimes a bleeep
i usually type the question (if its pretty normal) into google and it comes up with the relevant thread on sau
http://www.skylinesaustralia.com/forums/topic/119865-rb25-into-r32-basic-guide/
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
