R32 Dry Carbon Parts(Doors,boot,bonnet)
if you are after cheap china carbon overlay stuff go to the sponsors section and grab a bargain
if not read on
all parts Australian made
all parts Carbon fiber, dry laid, vacuum formed and resin infused with a clear gel coat finish
This gives them a very good weight to strength ratio.
eg same shit as f1 cars
if you happened to be a world time attack and saw the carbon r35 gtr's the guy who made all the panels for them makes this stuff so its the shit
prices as listed if we get more than on order we get a cheaper price ( thus the group buy)
ill put up a price in fiberglass later if people are interested
carbon doors $3,800.00 pair
These are made to take the OEM hinges, lock and internal handles. For ease of install and operation.
They are also made to take a polycarbonate, fixed window( additional cost)
r32 boot $1800
This one is simply aero catched down but they are normally made to take the standard hinge set up.
R32 bonnet $2000
Again this one is held down with aero catches. But we can easily make it to take the OEM hinge arrangement.
Really a genuine race type of dash. $3500
dash display is up to buyer e.g. Motec, Racepak, AIM etc.
they also do a carbon roof
3k intsalled
so if you want some drop me a pm
if we get a few people wanting some the price will drop
pete
https://www.sau.com.au/forums/topic/375265-r32-dry-carbon-partsdoorsbootbonnet/
prices are out of this world.
you can get NZ made carbon bootlids for $700
doors are like 1200 a pair from NZ
same with full carbon dashes can be had from US for 1000-1200
think this guy is having a lend of you bro.
link me
would be interested to see if its the same type of carbon?
because i can get "carbon" stuff for the prices you say but its not the carbon above
it would be plug molded not vacuumed formed to start with. i don't remember the mob in the NZ starts with a R but have bought from them before. it wouldnt be up to the quality of above but for price comparison / fitment you would be out of your mind to spend the money above. on another note even some of the china stuff has extremely good fitment these days.
How u can even compare china shit to this is stupid. Pricing is fair enough as its top quality !
Just for the record I have an oem boot n bonnet as above from custom carbon for 3500 as I sold my car
Price seems very fair...
description is a little far fetched F1 technology is a bit more advanced than resin infusion.
I have a few contacts in the F1 composites world and they are all using Pre-pregs.
I am very interested in talking with the guy making this stuff, I make the same products in the same way and I would like to support his business.
You have a PM Fatz
Great to see more people out there making this stuff.
Noy
That carbon dash baby jesus smile! need to get some of this same gear but for R33's :thumbsup:
Top quality workmanship thats for sure
That carbon roof also that reminds me of that silver R32 that Garage Saurus built that was featured in HPI a little while ago, simply epic!
Edited by Weapon
The guy's at Custom Carbon can do R33 GTR parts to if cost is a bit hi for most of you they make them in fibreglass too and it's the same process as the carbon one's I think they are about $1500 and when they are painted they look and fit just right you can't compare to the shit that comes out of china.
  • 1 month later...
The panels made in nz are same build as whats in china fibreglass backed with a single layer of carbon fibre for looks.
Also fatz what do the doors with the lexan windows weigh & price on them.
cheers Jason.
Edited by jas/slo32
cheers Jason.
bare door weighs just over 3kg's
lexan windows $570 fitted.. not sure on weight as they are very light
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
