Hello all,
I need a bit of help with the stock flow rating of injectors and whether they are top / side feed / low or high impedance.
I am trying to suss out what will fit in my RB30 fuel rail (I am doing a turbo conversion, RB30 R31 skyline). I have searched online and on the R31 forum but it seems lots of people are running an assortment of injectors without the info behind how.
Can someone please check this list? And help me fill in the blanks:
RB30E: 185cc side feed low impedance
RB30ET: 259cc side feed low impedance
RB20DET: 270cc top feed high impedance
RB25DET: 370cc side feed high impedance
RB26DETT: 444cc top feed low impedance
Does this all look correct? Is there any way to allow my skyline to accept high impedance injectors?
I will be running a VL turbo ecu, and if I can find no other options I will run VL turbo injectors also, but it seems a lot of the other RB series injectors are cheaper and flow better.
Thanks.
https://www.sau.com.au/forums/topic/375295-need-help-with-injectors-comparison/
I thought RB30E/T were top feed with hosetails?
I'm not sure at all, would anyone be able to confirm about the RB30 injectors?
Thanks very much for those tables mate! Very helpful, once I confirm what sort of injector the RB30's have stock I will use this for reference.
You will have to run the right injectors for the computer you are using or use an aftermarket computer.
Thanks for the help guys. Glad to hear that RB20 redtop are the same as VLT, i'll keep an eye out for those too.
With a VLT ecu, could I run other injector that flows similarly? Or would any different injector require a new ecu?
Thanks.
Thanks.
The injectors will need to be identical or it will run rich or lean or not at all.
Apologies to bump this up again, I need more expert help!
Just wondering, if anyone has had any experience with Bosch Green Top A46-000001 ? Out of a Nissan EXA / ET Turbo pulsar, supposed to be 272cc (only 3cc more than VLT injectors) and are still low impedance top feed with hose tail, same as VLT and RB20DET redtop. Can anyone confirm any of this?
Many thanks for all the time and help.
correct e15et injectors are the very same as the vlt injectors
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
