Ok finally got around to uploading some in car vids...
First one is my fastest lap. As stated earlier in the thread some of the vid is washed out due to the exposure issues. Look out for the understeer of fail moment coming onto the straight :blush:
Sandown Fastest Lap
Next is the battle I had with an Evo and ended up out braking myself at the end of the straight...check the wing mirror to see how close he was!
Evo Battle
And lastly a bit of a fishy coming out of the Dandy Rd section...
Fishy
Enjoy :)
  • Replies 128
Posted Images
How is the bite on them?
I wasnt a fan of the Ferrodo DS3000
So thinking either Pagid RS29, or perhaps another pad.
Very good bite. Predictable. Can't fault them really. DS3000's to me seem like rotor killers. Pagid's are expensive I hear..
bugger about the camera! freakn washed out.
Mine from the same day, same camera, same position in the car. I have the metering setting set to 'spot'. I have also upgraded the firmware.
Yeah my Phillip Island footage was even worse! My metering was set to 'centre' and I have upgraded the firmware as well. What I might need to do is set the metering to 'average' or go for a drive on a sunny day to sort the settings.
hopefully this might help white out issue.
centre > often short for centre weighted, ie exposure taken from full frame including dark interior but weighted more to what is in the centre.
Spot > exposure is taken from a spot(centre)
looking at the footage where do you reckon the centre is? John's is the track, Ant do you reckon yours is the top of the dash? Basically I think I did the same thing at Sandown, centre was the dash resulting in over exposed track. At the last PI event, centre was the track and worked really well for the bright conditions. Mine is HD Gopro with firmware upgrade.
If only I could dashware or rachchrono dials to work without glitches for my gps data(10hz).
glitches? You have a qstarz 10hz? I have a older 5hz, but the guys use a 10hz and I have used their data before.
In saying that, R2AVI does crash and crap it self with the data sometimes,
The result is you have to export each lap one by one. It sucks when this happens. Generally later in the day, not sure if it is a battery thing.
HAHA! Nice catch
LOL the old battle between the brain saying GET OFF IT and the heart going for a quick time :) Meanwhile the eyes are going 'oh look theres a wall over there...wait, wait theres a wall over there too...'
As for the cameras metering I figured it was a case of the metering point being on the dash rather than out of the windscreen. Like I said I need to strap it in the car and go for a drive on a sunny day to get the settings just right.
Guest
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
