Ok so here it is guys and gals,
I have a near factory condition 1994 R33 series 1 2dr GTS Skyline. Now it is different from all my past cars, but i am thinking not quite different enough . . . . . I wanna chop the top and get some air in my hair before it all falls out in my midlife crisis.
i am trying to figure out some way to cut it back and find someone to make either a carbon fiber or fiberglass detachable roof. Now i know that alot of the structural integrity of the car is held in the roof so there will need to be some major engineering to be done to the rest of the chassis.
So what i need to know if anyone can tell me is, what is needed to be done in the way of engineering? and is there anywhere good in southern QLD to go for this preferably in the toowoomba area?
Any advice is great guys
Thanks in advance :)
https://www.sau.com.au/forums/topic/375396-is-it-possible/
SUNROOF maybe???
https://www.sau.com.au/forums/topic/375396-is-it-possible/#findComment-5987988
You'll never be able to get it engineered and road legal and I think you are underestimating how much something like that would cost to do properly.
I am aware that the cost will be more than substantial, heck i have 20k put aside for this project so far. I am not worried about the hanndling as i only use it as a cruiser not a high performance beast anway
I didnt ask to be told that it cant be done, because in my eyes nothing is impossible, i asked because this is one of the few site i have found where some people know what they are talking about and might have some useful advice.
https://www.sau.com.au/forums/topic/375396-is-it-possible/#findComment-5988087
Didn't say it couldn't physically be done. I said to get it approved/engineered in QLD to make it road legal would be next to impossible.
The handling is the least of your worries. The roof/windscreen make up the main structural rigidity of the vehicle. There is a reason why convertibles weigh 30-60kg more than the equivelent coupe/sedan as they have to make up for the structural loss. Hell drive a factory aero-top Supra with the roof off and feel the whole car twist and vibrate; and that's a car that was engineered properly by the manufacturer.
You wanted advice, we are giving it to you. If you want people to blow some smoke up your ass by saying "Yeah man do it, piece of piss, just chop the roof" then go on Boostcruising.
As said above. You want a nice Nissan convertible cruiser buy a Varietta and drop a turbo motor into it. Will also look a hell of a lot better.
https://www.sau.com.au/forums/topic/375396-is-it-possible/#findComment-5988236
For starters; Double your budget. At least.
How much are you planning to do yourself?
A custom made Carbon fibre roof and attendant mounting structure? I'd say that would be all of your original budget right there.
You are right; nothing is impossible. The question is; can you afford it?
I would suggest you go and talk to a race engineer or a rod shop that does a lot of custom steel fabrication. If you are serious (and they'll be able to tell :whistling: ) they'll be able to outline the issues that will cause problems, and also the costs.
Go from there.
And when you start; do a build thread for everyone to follow.:thumbsup:
https://www.sau.com.au/forums/topic/375396-is-it-possible/#findComment-5988257
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
