Well I finally had my GReddy Ex Cam Gear (bought from www.nengun.com) installed (-4) at www.uniqueautosports.com.au yesterday and immediately noticed a difference. I noticed at the drags recently that my top end seemed to be flat and well the dyno graphs showed that.
Kudo's to John, Adam and Ben at UAS. Just need to get my Clutch bits'n'pieces sorted out now and i'll be back at the drags aiming for that mid-high 13sec.
Mods:
RB25DET - 88,000km
Standard ECU
Standard Turbo
Sports Organic Clutch (Daiken Exedy)
FMIC (Micks Metal Craft)
TurboXS Dual-Stage boost controller (not holding boost)
3" Front/Dump pipe (custom)
3" Cat (custom)
3" Cat-back (Nismo)
Panel Filter (K&N)
Bosch 040 Intank Fuel Pump
GReddy Ex Cam Gear (-4)
= 186rwkw
Before/After
Edited by benm
https://www.sau.com.au/forums/topic/37541-ex-cam-gear-beforeafter/
  • Replies 54
Posted Images
That's a really good result you've got there. I didn't get anywhere near that improvement with mine. In fact I'd say that my cam gear install has just shifted the power band up the rev range a bit and put a dip in my torque curve. I wonder how they minimised the dip at the bottom of the torque curve that I've noticed most people get on yours. I'd be happy with that result Ben.
Looks like you've got yourself a factory ECU that likes to play the game! Very lucky!
My factory ECU headed for sub 10's A/FR territory as soon as any additional AFM voltage was recorded (i.e more boost, cam adjustments and so on...)
Hay it's funy cause with the cam gear install you got rid of the flatspot up high.
Sure did, fixed the problem that I wanted fixed most... I need better TS at the drags :D
Why, I have no idea, but I love it  :DJ
Have you got a '95 ECU like me ?
Nope, I've got a 93 ECU...
I'll find a link to my dyno sheet, my flatspot was worse than yours and seems to have gone. Sometimes I can feel that it's back (but no where as bad) but then it goes again..
Damn ECU crap..
J
Edit: Here it is.... http://www.skylinesaustralia.com/forums/sh...ead.php?t=33043
  • 4 weeks later...
