Hey guys,
if this is happening to you: post-36975-0-95260700-1314502383_thumb.jpg
then you need to replace the little heater core at the back of your dash as it has started leaking. My signs were: strong smell of coolant in the cabin, front windscreen fogging up, loss of coolant in the reservoir and then at the end of it my passenger foot well started leaking coolant.
As I have already removed my aircon line because it split years ago, I didn't need to worry about disconnecting the aircon lines... if you do this, you will loose all the gas in your aircon.
Tools: phillips heads, flat heads, maybe pliers, spanner set, possibly socket set
Should be about an hour to get it out..
1. Remove Glove box - There are 4 screws at the top and 2 plastic tabs at the bottom of it where it hinges to remove.
post-36975-0-70939300-1314502605_thumb.jpg post-36975-0-64857800-1314502608_thumb.jpg
2. Remove plastic backing to glove box which hides aircon evaporator thingy - I think there is just 2 screws and then a decent tug should do.
3. This is what you should see, this is the aircon evaporator, we need to remove it.
There are 4 screws holding it in, plus 3 electrical plugs, plus the 2 aircon lines(mine was already removed)
4. Once all those are disconnected, give it a good smooth tug and this is what you should see:
post-36975-0-30403000-1314503278_thumb.jpg post-36975-0-05497000-1314503298_thumb.jpg
Now we need to get back here
5. But before you do, disconnect the lines going to the heater core or coolant will spill all over you
6. Now, back under the dash at the back there are 4 phillip head screws per line, undo the screws plus one screw for the plastic tab that holds the core in place.
7. Thats it! you should now see this
post-36975-0-72984600-1314503715_thumb.jpg post-36975-0-04787800-1314504012_thumb.jpg
Gently slide it out trying to point the holes up as much as possible so they don't spill
Yep... its leaking...
post-36975-0-19801400-1314503869_thumb.jpg post-36975-0-52807000-1314503795_thumb.jpg post-36975-0-72431900-1314503808_thumb.jpg
So this is what you will be left with...
Get a replacement ($60-100) and do the reverse, top up some coolant (check for air locks etc) and your back on the road
Adam
  • Like 1
Mine done same thing. I decided on new core and removal of dash.
Done dash before so was eazy. And that way you dont need to regas aircon.
I ended up getting new core dont want to same thing to happen anytime soon.
Btw great writeup :)
  • 3 months later...
  • 1 month later...
Update - I picked up a complete (whole plastic box + lines and heater core) in great condition for $70.
Awesome cheers heaps for that that'll make it alot easier now shouldn't take to long i hope but if it does oh well
thanks heaps man.
Cheers Toby
  • 3 weeks later...
  • 3 weeks later...
Ok my gone now and have done the bypass as well but I have a question to the above tutorial as in ....
What if youu still have a valid working air conditioning unit and how dowes this change the procedure to change the heater core?
Dazza
If you want to retain your aircon in a working state while doing this you have to literally remove the entire dash to get back there so you don't have to undo the aircon lines - as soon as you open them you will release the gas = no more aircon.
I'm going to put the aircon lines back in my car soon and get them regassed.
IMHO though, even if I had aircon at the time when this happened, I would still fix it the way I did above and just get the aircon regassed for ~$100 then to spent 4-6 hours just removing the dash instead of 1 hour.
  • 8 years later...
Heads up on this useful guide. Just changed out my R33 core sourced from Kudos motorsport. I removed the passenger seat, was quite comfortable laying there on the carpet.
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
