Hey guys,
if this is happening to you: post-36975-0-95260700-1314502383_thumb.jpg
then you need to replace the little heater core at the back of your dash as it has started leaking. My signs were: strong smell of coolant in the cabin, front windscreen fogging up, loss of coolant in the reservoir and then at the end of it my passenger foot well started leaking coolant.
As I have already removed my aircon line because it split years ago, I didn't need to worry about disconnecting the aircon lines... if you do this, you will loose all the gas in your aircon.
Tools: phillips heads, flat heads, maybe pliers, spanner set, possibly socket set
Should be about an hour to get it out..
1. Remove Glove box - There are 4 screws at the top and 2 plastic tabs at the bottom of it where it hinges to remove.
post-36975-0-70939300-1314502605_thumb.jpg post-36975-0-64857800-1314502608_thumb.jpg
2. Remove plastic backing to glove box which hides aircon evaporator thingy - I think there is just 2 screws and then a decent tug should do.
3. This is what you should see, this is the aircon evaporator, we need to remove it.
There are 4 screws holding it in, plus 3 electrical plugs, plus the 2 aircon lines(mine was already removed)
4. Once all those are disconnected, give it a good smooth tug and this is what you should see:
post-36975-0-30403000-1314503278_thumb.jpg post-36975-0-05497000-1314503298_thumb.jpg
Now we need to get back here
5. But before you do, disconnect the lines going to the heater core or coolant will spill all over you
6. Now, back under the dash at the back there are 4 phillip head screws per line, undo the screws plus one screw for the plastic tab that holds the core in place.
7. Thats it! you should now see this
post-36975-0-72984600-1314503715_thumb.jpg post-36975-0-04787800-1314504012_thumb.jpg
Gently slide it out trying to point the holes up as much as possible so they don't spill
Yep... its leaking...
post-36975-0-19801400-1314503869_thumb.jpg post-36975-0-52807000-1314503795_thumb.jpg post-36975-0-72431900-1314503808_thumb.jpg
So this is what you will be left with...
Get a replacement ($60-100) and do the reverse, top up some coolant (check for air locks etc) and your back on the road
Adam
  • Like 1
Mine done same thing. I decided on new core and removal of dash.
Done dash before so was eazy. And that way you dont need to regas aircon.
I ended up getting new core dont want to same thing to happen anytime soon.
Btw great writeup :)
  • 3 months later...
  • 1 month later...
Update - I picked up a complete (whole plastic box + lines and heater core) in great condition for $70.
Awesome cheers heaps for that that'll make it alot easier now shouldn't take to long i hope but if it does oh well
thanks heaps man.
Cheers Toby
  • 3 weeks later...
  • 3 weeks later...
Ok my gone now and have done the bypass as well but I have a question to the above tutorial as in ....
What if youu still have a valid working air conditioning unit and how dowes this change the procedure to change the heater core?
Dazza
If you want to retain your aircon in a working state while doing this you have to literally remove the entire dash to get back there so you don't have to undo the aircon lines - as soon as you open them you will release the gas = no more aircon.
I'm going to put the aircon lines back in my car soon and get them regassed.
IMHO though, even if I had aircon at the time when this happened, I would still fix it the way I did above and just get the aircon regassed for ~$100 then to spent 4-6 hours just removing the dash instead of 1 hour.
  • 8 years later...
Heads up on this useful guide. Just changed out my R33 core sourced from Kudos motorsport. I removed the passenger seat, was quite comfortable laying there on the carpet.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
